Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Fagor Automation
Fagor Automation Discuss Fagor Automation products here.
Old 12-08-2009, 01:45 PM
Todd H is on a distinguished road
Fagor 8025 Rapid problem
Hi all,
I have a Mitek mill with a fagor 8025 controller and Glentek brush type servo drives. When drilling with the Z axis, drill load was too high causing a following error and subsiquently the machine stopped. This has happened on ocation before, and simply hitting the E-stop and starting over was all that was necessary. This time, after restarting the Rapid override doesn't work when using the axis control buttons in Jog mode. I did a quick Teach in of M00, and rapids worked, so it seems the problem is limited to manual/jog input.
I bought this machine used a few years ago, and haven't been able to reach Mitek since just after I bought it. I can only assume they aren't around anymore.
I'm a machinist, not an electronics or maintinance guy, and while I'm fairly good at diagnosing problems, I don't know where to start with this. All fuses I can find are fine, not sure if there is a breaker/reset hiding somewhere. There are a few components in the enclosure I'm not sure of, and therefore can't identify what parts are involved.
I've included a picture of the enclosure showing the components.
Thanks to all, any advise is greatly appriciated.
Fagor 8025 rosli Post Processors for MC 1 11-17-2011 03:40 PM
fagor 8025-ms controller problem jcarls Fagor Automation 4 04-06-2009 02:42 PM
Fagor 8025 parameter help Oregon Rich Fagor Automation 1 01-27-2009 09:56 AM
Need Help!- Fagor 8025 / GE MarkCenturyONE refit problem Odin M Yggdrasi Controller & Computer Solutions 6 07-14-2008 10:11 PM
fagor 8025 threading Rivet head General Metal Working Machines 4 09-23-2005 06:25 PM
