Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Fagor Automation
Fagor Automation Discuss Fagor Automation products here.
Old 11-22-2009, 12:20 PM
Captdave is on a distinguished road
Checking following error 8025
I'm still having problems with threading, I have replaced the encoder and it still won't pick up and follow the previous thread.
Anyone know how to check the following error? The machine holds dimensions well so I'm inclined to think it's not a servo problem.
Old 12-06-2009, 03:33 PM
pipes is on a distinguished road
Following Error display
You can display the following error by selecting the "Following Error" soft key (F keys at the bottom of the screen) when in Auto or Single Block modes.
Write a small program that runs the axis you want to check at a rate of about50-100ipm back and forth in a repeating cycle.
The error should be the same in both directions, if not you may have to adjust your Balance on the servo drive.
If you are comparing two axis then each should be the same within the smallest count you can get it (varies by machine topology). If they are not you should adjust the gain on your servo down on the higher one until it is equal to the lower one. Verify that the numbers on each are the same in both directions.
Verify there is no drift or axis grumble when the motors are stopped after tuning.
This can be an iteritive process, however, if you are tuning the drives use very small adjustments of the pots as small changes can have a big impact on the velocity loop.
If you do not have it already you should go to the Fagor Automation website and download the 8025 Setup and Installation manual as well as the User Manual.
Need Help!- Checking My Servos MSGMachine Servo Motors and Drives 4 11-21-2009 11:06 PM
Need Help!- Fagor 8025/ accuslide error 099, M-tables lost Tinmuk Controller & Computer Solutions 0 07-25-2009 10:45 AM
Newbie- Checking out a hurco Dave Rothermel HURCO 3 07-16-2009 05:33 PM
CHECKING CHANDRU Fanuc 1 12-24-2007 07:48 PM
Newbie checking in. jstuedle DIY-CNC Router Table Machines 10 06-30-2004 10:58 PM
