Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Fagor Automation
Fagor Automation Discuss Fagor Automation products here.
Old 11-10-2009, 10:03 PM
Stupidav is on a distinguished road
Unhappy 8055 Motion Master Problems
Major problems with control operation. Attached are the programs that we are attempting to run. In this case they are a simple 2d operations. The first step we are facing the the box, in which the part surface is equivelant to the table, not Flat (we are thinking play in the linear rails, possibly ). Then the second operation in putting in a grove around the inside, although the first cut operation is off (98% of the time) in the X by .02" to .08" and every Z step after is perfect in respect to X. On the second operation I am getting a drop in Z of .05" over a 72" span as Y increases, no steps gradual. Even though we are seeing the Z go - as Y goes + it does not even come close to the facing operation. On top of this the Display does not show the change in Z.
The Zip has both the Surfcam generated code as well as the uploaded code from the controller. P000001 is the First / Facing Operation and P000002 is the Pocket / Contour Operation.
Any help Ideas are greatly appreciated! I am just on the lost side of things with these problems.
Attached is a picture of the part that we are getting.
Old 11-11-2009, 07:56 AM
DareBee's Avatar
Monkeywrench Technician
DareBee is on a distinguished road
Sounds like the mill-itself is not set-up correctly as well as proper compensations for the individual axis.
www.integratedmechanical.ca
Old 11-11-2009, 09:06 AM
The only problem is that some times it works just fine. I downloaded all the manuals last night so I can see if there is somthing that I am missing.
The facing op ends up as:
x0y0 z=0.0 then x48y0 z=-.012 then x0y72 z=-.018 last x48y72 z=.01
This is totally different than the .05 slope we are seeing when we do the inside pocket. Which is why we are thinking the control, rather than the machine. At the same time frequently if we start at the oppisite side of the part, it is looking like we don't have the problem (will confirm some more today on that).
Old 11-11-2009, 09:52 AM
SCRAPWOTSCRAP is on a distinguished road
1. Is the table leveled? 2. Is the surface below your workpiece faced? or is material mounted directly to the table? Is the Motion Master rigged for vacuum hold down or just a flat steel table? You might want to use spoil material under and face that first to ensure flatness. Then your workpiece, you might see better results. Is this a 3 axis Motion Master or a 5 axis?
Old 11-11-2009, 05:26 PM
This is a 5 Axis Motion Master, with a Second Table "U", The unit is setup for vacuum but that is currently off the machine andthe part is anchored directly to the table, which is faced. We did go over the leveling, but what is throwing us is that the facing operation, the first operation, isn't even parallel to the second operation. If they were even close to being parallel then I would definatly be going all over the machine releveling.
I just double checked, on some different parts that were not critical and found we had the same issue.
Does anyone else have a Motion Master? If so what do your program headers look like? Should we be clearing anything?
Old 11-12-2009, 08:16 AM
DareBee's Avatar
I don't have time to go through your program - but now it sounds like either Surfcam is giving you whacky code or the model that you programmed from has bad geometry.
You are trying to troubleshoot too many things at once.
Start with the machine and control.
Try hand coding a couple of simple straight line cuts and check them for accuracy.
Old 11-12-2009, 09:37 AM
I think I may have the X step issue figured out (Mechanical Issue), I will explain in a little while. I am running some more test to see if it occurs again. If it does it is somthing every Motion Master owner should know.
Motion Master 5 Axis Router.......Fagor 8055/C.......Surfcam Velocity 4.0 B189
Old 11-12-2009, 09:50 AM
Have you inspected axis drive belts for wear and tightness? On 5 axis the z counterbalance cylinder seals can be an issue. Servo encoders can also be a problem. Worked with Motion Masters for 6 years, doubt this is a control issue.
Old 11-12-2009, 01:02 PM
Just peeked at your programs..... you don't have much of a header. Start of our Fagor progams included these lines in the header:
G40 G44 G53 G80 G90
G51 E.005
Check your programming manual for g code definitions the G90 is Absolute versus G91 for Incremental. Wish I had more time, waaaaaaaay busy here.
Old 11-18-2009, 12:19 PM
ericandmollie is on a distinguished road
MotionMaster Problems
It is rare to see someone talking about a Motion Master. Not too many left out there. We have two twin table 5-axis motion masters that I have programmed with surfcam and run for 12 years. I love the machines, but getting support is virtually impossible, since they went out of business. I hear the main guy started another company in Texas, somewhere.
Does your z-axis plunge on the left table (M14) as well as the right table (M15) when milling in the Y direction? Does it plunge when milling in X driection?Also check your air supply to your z-cylinder, regulators, and filters. What about your leveling pads in the front and back? Are they loose? The last thing I would do is attach an indicator to the head, touch down on table, then run table back to check for level.
  #11   Ban this user!
Old 11-18-2009, 01:54 PM
One of them went here: http://www.westerncncinc.com/AboutUs.html and they still help out. Good peeps. If you have a Motion Master their machines will look just a little similar.Thought you should know since you have two of their twin table 5 axis, hope you don't have that wacked early tool changer.
  #12   Ban this user!
Old 11-18-2009, 04:00 PM
focusroger is on a distinguished road
Your file header information is completely missing. I don't think this will solve all of your problems but most of them. I am having a problem with my motion master 5 axis fagor also but i might be an encoder on the Z.. Here is some code you need in your files the most important is G51 E0.01 (look ahead tolerance) with out this everything we be "average" out of spec... You need to download the fagor 8055 programing manual as well obviously.
%TEST R ,-MX,
;(CUSTOMER- )
;(PROJECT- )
;(DRAWING NO- -REV-A)
;(OPERATION- )
;(MATERIAL- ALUMINUM INCH - 2024)
;(CYCLE TIME- )
;(PROGRAMMER- )
;(MASTERCAM FILE- TEST.MC9)
;(DATE- 11-18-09)
;(TIME- 12:15)
;(TOOL INFORMATION)
;(POSTED WITH 10.1811 TOOL LENGTH)
;(SAFETY CODES)
G53 ;CLEAR ALL ACTIVE OFFSETS
G44 ;CANCEL TOOL LENGTH COMPENSATION
G90 ;ABSOLUTE/INCREMENTAL MODE: G90=ABS G91=INC
G49 ;CANCEL INCLINE PLANE DEFINITION
G40 ;CANCEL TOOL RADIUS COMPENSATION
G10 ;CANCEL MIRROR
G17 ;SET PLANE TO X-Y
G80 ;CANCEL CANNED CYCLE
G70 ;PROGRAM UNITS: G70=INCHES, G71=MILLIMETERS
G94 ;FEED MODE: G94=INCHES/MIN. G95=INCHES/REV.
G01 G53 Z-1.0 F100.
G00 B0.C0.
G51 E0.010 ;LOOK AHEAD TOLERANCE (E)
;(START FILE)
T1
;( Undefined )
S18000 M3
G53 Z-1. F100.
;(ORGX54=0,ORGY54=0)
G54
CODE HERE...
THEN... END OF FILE IS
M5
G53 G01 Z-1. F100.
G53 X0 Y0 B0 C0
M30
focusroger
motion master conversion Montabelli Granite Devices 20 05-17-2010 02:49 PM
Need Help!- Siemens 810M 1720 ORD + X error (Motion Master Router) mjhjenks Controller & Computer Solutions 6 03-02-2010 05:06 PM
motion master going granite Montabelli Hobbycnc (Products) 0 09-30-2009 11:22 AM
Motion Master Router with AB9/260 alexplace2001 General CNC (Mill and Lathe) Control Software (NC) 0 08-03-2009 01:59 PM
Motion Master router Jennifer DIY-CNC Router Table Machines 6 10-16-2004 12:26 PM
