Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Fagor Automation
Fagor Automation Discuss Fagor Automation products here.
Old 11-10-2009, 09:08 AM
Jerry Shorter is on a distinguished road
8025 and infinate program with DNC?
The 8025 manual says that I can send an infinate program to my 8025T using DNC however it also says a program must be numbered with a limit of 9998 blocks, I did try to send a program without block numbers, but the control wouldn't accept it because the block numbers were missing. soooo, anyone have any Ideas?
Jerry
Old 12-08-2009, 02:01 PM
Todd H is on a distinguished road
I have an 8025 on a vertical mill, when I did this before I used fagor's DNC software, had numbered blocks, and broke the program into logical chunks. Then essentially ran multiple programs to finish the part. The 8025 sadly isn't the most advanced control. Be sure you've got a good connection between control and computer, I had the communication drop out multiple times.
Old 12-09-2009, 09:46 AM
DareBee's Avatar
Monkeywrench Technician
DareBee is on a distinguished road
Fagor has a trade in/up promotion going on right now.
I was sent a flyer a few weeks ago.
Can't remember exactly but I think the upgrade was to an 8035 or an 8040. I don't believe my 8040 has a line limit.
www.integratedmechanical.ca
Old 12-10-2009, 05:17 PM
Thanks for the reply guys, I guess I can get along with breaking th pgm's up into smaller blocks. I was just hoping against hope that I wouldn't have to.
Jerry
Old 12-10-2009, 11:44 PM
Fagor - Todd is on a distinguished road
Jerry
No, there is a way around this.... I'll have to think about what it was. (Its been a lot of years since I did Infinite length execution..... but in the past I had run some very long programs that went over 9998 blocks..... but I don't remember how I did it) Give me a day, and I may have a solution for you.....
I also recommend you download the latest and greatest DNC software version from our Download section at www.fagorautomation.com (DNC Software is free as a download)
But, yes the 8025 is an old technology control for us that we haven't manufactured in many years, all newer controls can easily do this, in fact, they typically do not need to be drip feed considering there is ample memory with most models to run very large programs from resident memory.
We do have upgrades to our 8035 CNC which is a modern CNC, but shares the same physical size as the 8025 and can literally be a 1 day retrofit..... just talk to your Regional Salesman if interested in upgrading.
Old 12-11-2009, 12:09 PM
I also recommend you download the latest and greatest DNC software version from our Download section at www.fagorautomation.com (DNC Software is free as a download) .
Wow, Todd that would be great if you could remember how to do it. I really appreciate your help. I downloaded WinDNC 5.1 a few months ago, I think that it is the latest version. I have it working just fine. I just purchased an new 8035T. I am now tring to learn how to program the PLC.(a bit different than ladder logic) The 8035 seems like a very powerful system. all kind of goodies. and is certainly nothing like the 8025 although the 8025 is a solid system. I was suprized that the 8035 uses a Linux O.S. Anyway I think it will a very good system.
Jerry
Old 12-11-2009, 01:38 PM
Jerry
Hi Jerry,
The 8035 CNC was a purpose built CNC to replace/upgrade over the old 8025 series. Hence, the compact design the same as the 8025. It is a modern CNC based upon in part the 8055, however, the 8035 is limited as compared to the 8055..... one of which is the conversational operating system that you can have on the 8055, whereas on the 8035, it is strictly G-code. But, for what it is, its a step in the right direction over the old technology 8025's..... as a note.
On your PLC program, we have a program that emulates the basic I/O of the 8025, thus your PLC program is basically done by Fagor...... perhaps that was not loaded for you ? I do not know. Consider calling 1-800-423-2467 and talking to Service Department, they can email you the PLC program and you can then download via DNC to your 8035. I won't tell you the PLC program covers all I/O requirement situations, but its a big jump start.
We also have good working PLC examples of Turret logic.... this can be accessed here: http://www.fagor-automation.com/Tech..._CNC_8055.html
Keep in mind the 8040/8055 PLC methodlogy is the same.....
If you need any documentation downloaded, from our International Website, you can go to our download center and download manuals, brochures, etc.... a lot of people do not know that we have additional manuals beyond the Programming/Operating and installation manuals such as an error solving manual and examples manual and new features manual that can all be accessed at the below link.
http://www.fagorautomation.com/_bin/descargas.php
One other note, on 8025 infinite length execution regardless of program size, you simply start over on the block numbering once you get to 9999, go back to 1, and recount up again..... it will run no problem, however, obviously you can have any jump or loop commands in the program. (As a note, The 8035/8055 series CNC does not require block #'s unless you do have a jump or loop)
This might be sensitive to your software level considering you have a new version that is designed for later model controls..... if it doesn't work, let me know.
Hope this is kinda of helpful !
Good Luck !
Old 12-11-2009, 02:01 PM
Thanks for the valuable info Todd, I''ll check it out. I replied to your P.M. Let me know if you want that info.
Jerry
Fagor 8025 rosli Post Processors for MC 1 11-17-2011 03:40 PM
8025 GP,M,MS serial communication midnightrambler Fagor Automation 4 04-23-2009 12:10 AM
G-Code on Fagor 8025 midnightrambler Fagor Automation 6 02-09-2009 03:53 PM
Help with radius with 8025 tg Captdave Fagor Automation 0 02-06-2009 08:05 PM
Fagor 8025 parameter help Oregon Rich Fagor Automation 1 01-27-2009 09:56 AM
