Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Fagor Automation
Fagor Automation Discuss Fagor Automation products here.
Old 08-06-2009, 01:37 PM
Jerry Shorter is on a distinguished road
Unhappy Fagor 8025T dripfeed problem
Hello,
I'm having problems figuring out the proceedure to drip feed to my 8025T using the DNC option. I am able to send programs back and forth between my laptop and CNC using various terminal pgms (PCWIN, Hyperterminal, etc.) with no problems. So I'm sure that my cabling and protocal are correct.
I have WinDnc set up at 1200,7,e,2 (same as PCWIN and CNC) However I always get "TRANSMISSION ERROR". when I press send in WinDnc
I'm not sure how to set up the CNC to recieve dripfeed: other than Op Mode 7 -6 (DNC ON) Then what?. Do I start the transmission from Windnc at this point or do I go to Op Mode 0 and start the transmission. (tried both with no luck)
The Auto screen has DNC flashing at the top of the screen and below that is N* If I push start at this point I get "error 014".
Maybe my whole though process is wrong. (wouldn"t be the first time.) any help would be greatly appreciated.
Jerry
Old 08-06-2009, 02:54 PM
SCRAPWOTSCRAP is on a distinguished road
According to this:
http://www.connectcnc-dnc.com/Settin...r%208025t.html
dripfeed is unavailable on 8025t. Maybe "fagortodd" will jump in on this one.
Old 08-06-2009, 04:03 PM
Thanks for the quick reply Scrapswot, I hope that is not the case. I'll hold on for further info.
Jerry
Old 08-06-2009, 04:18 PM
I know for a fact you can dripfeed with the 8050's and 8055's was surprised to see that for the 8025, I hope it's not the case for your sake. Good luck!
Old 08-06-2009, 08:26 PM
Fagor - Todd is on a distinguished road
Hi Jerry,
Dripfeeding is done via the Infinite Length Execution mode on most DNC versions. You do not have to touch the CNC.... just select the program and starting block and the mode you are executing in. (0 = automatic mode typically)
If you do not have the correct DNC (Which might be an older version), call the Fagor Service Department and request for them to send you a copy via email. (All DNC software from Fagor is free of charge) You can reach the service department at 800-423-2467 Most anybody can help you.
I have used the feature countless times, it always works and considering you are able to upload/download programs, we know the communication channel is operational, so you should be good to go....
Sincerely,
Todd
Old 08-06-2009, 10:21 PM
Hi Todd:
Thanks for the info, I will give it another try I'll let you know through this thread how it turns out.
PS. any comment on the 8025T not being capable of dripfeed.
Jerry
Old 08-10-2009, 10:16 AM
Talking
OK, I got dripfeed to work, The answer to the problem was two fold.
The protocal and end of transmission code.
The protocal for DNC is not the same as the protocal for other file transfer programs. WinDnc must have (baud,8,N,1) . Other programs can use (baud,7,E,2). But also N,8,1
End of file character must be a (NUL) Not an (ESC). Other programs can use an (ESC). but not WinDnc.
All is well, Thanks to everyone for the help.
Jerry
P.S. SCRAPWOTSCRAP, The info on that WEB site might be only for their program, because the 8025T does indeed DNC using WinDnc.
Old 08-10-2009, 10:21 AM
Glad you got it goin, would have to agree about that software, was hard for me to believe no dripfeed option, knew Todd would come thru, I'm more familiar with 8050/55.
Old 08-11-2009, 04:50 PM
kcho is on a distinguished road
Hi, do you solve the problem? You need to work with the machine via DNC?
Old 08-11-2009, 04:59 PM
KCHO: yes I got it runnubg, thank you for the reply.
Jerry
  #11   Ban this user!
Old 05-26-2011, 04:48 AM
danlavi508 is on a distinguished road
i have fagor VPE 202 combi oven and the touch screen is not working can you tell wat is the problem
  #12   Ban this user!
Old 05-26-2011, 04:52 AM
Hello,
I'm having problems with fagor VPE 202 combi oven's touch screen is not working i cant set any operation can you tell me what is the problem ?
Tags
dnc, drip feed, dripfeed, fagor, rs232
Bobcad Post processer fagor 8025T Captdave Fagor Automation 5 05-06-2009 07:02 PM
fagor 8025-ms controller problem jcarls Fagor Automation 4 04-06-2009 03:42 PM
Need Help!- Fagor post Problem StoneCutting Post Processor Files 2 05-09-2008 04:58 PM
Fagor 8040 Dxf Problem Mert-G General CNC (Mill and Lathe) Control Software (NC) 4 09-29-2007 05:51 PM
Fagor Radius Problem KeithH G-Code Programing 3 09-08-2006 09:14 AM
