Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Fagor Automation
Fagor Automation Discuss Fagor Automation products here.
  #13   Ban this user!
Old 08-21-2009, 06:46 AM
Captdave is on a distinguished road
My USB is connected to port 6. Now I can't get WINDNC it to select any other port than 1. Grrrrrrr
  #14   Ban this user!
Old 08-21-2009, 01:23 PM
Jerry Shorter is on a distinguished road
CaptDave: if you double click on where it says COM1 in WinDnc setup it should open a window with the available ports. My laptop shows COM3,COM4 in WinDnc when I open the window. I did re-map my usb to Com3. although I'm not sure that was necessary.
Jerry
  #15   Ban this user!
Old 08-21-2009, 04:51 PM
I got the blue box to open and it shows COM 6, right or left click, double tap and it will not change for COM 1 to 6.
Another point, in the set up, local, I select 8025T and ok, then setup for the device 8025T and then save it, close the program and restart it shows at the bottom 8055. I have to go back and change it in the local line to a 8025T.
  #16   Ban this user!
Old 08-21-2009, 05:21 PM
be sure you save the setup.
  #17   Ban this user!
Old 08-21-2009, 08:56 PM
Is there another way to save it other than clicking OK?
  #18   Ban this user!
Old 08-24-2009, 08:58 AM
CaptDave: No that is the only way. I tried to duplicate your problem with the Com ports and sure enough it woudn't let me change ports. I closed it out and went back in and it let me change the ports. So I don't know what the heck is going on. There may be some kind of conflict in the port addressing. Make sure there isn't something else trying to use that port. Some programs can be set up to automaticaly grab a port and not let it go until they'er told to. I don't think WinDnc tells you when you have a port conflict.
Jerry
  #19   Ban this user!
Old 09-20-2009, 06:43 PM
MysticMonkey's Avatar
MysticMonkey is on a distinguished road
Why don't you use the software with the USB-Serial converter
Or windows to remap the port to COM 1?
