Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Fagor Automation
Fagor Automation Discuss Fagor Automation products here.
Old 06-30-2009, 10:51 AM
turboboost951 is on a distinguished road
Post Fagor Axis Modual error
I am getting a E106 Extreme temperature at the heatsink (of the IGBT's). " The drive is carrying out a task that overheats the power device. The LED screen on the side of the modual blinks E106 and when we looked it up that is the description. I have been running the CNC the same no changes have been made that would increase the effort needed by the drive. I have talked to Fagor direct and their not to sure what would be causing this. Has anyone else seen this problem or have any ideas??
Old 06-30-2009, 12:25 PM
yours_prabhat is on a distinguished road
you please mention the control model and drive spec so any one can help you
Old 07-01-2009, 10:39 AM
Im not sure the make of it the model is an Fagor AXD drive
Old 07-01-2009, 11:41 AM
please mail me on prabhatmishra@mail.com i will help you
Old 07-03-2009, 12:43 AM
kcho is on a distinguished road
Could you tell me what is the drive software version. when ocurrs the error.
Best regards
Carlos Cabrera
Old 10-14-2009, 09:23 AM
Mert-G's Avatar
Mert-G is on a distinguished road
If this error comes up when the system is silent (not started, no power applied to power supply module) then you should send the drive module to the relevant service to be repaired.
If the error comes up after the system is started;
1) you should check the power cable between the drive and motor.(short circuit)
If the cable seems OK;
2) change the motor connections of the drive and a drive next to this to see that if the new drive will show the same error. Remember that the drives and motors you are going to try in this step must have same specifications.
Old 10-27-2011, 05:06 AM
robertlonan is on a distinguished road
Dear friends,
Kindly advise me how to solve the error 2 (E2) in Fagor AXD 1.15 drive.
Regards,
Robert
Old 12-29-2011, 10:05 PM
CNCTech25 is on a distinguished road
E106 is overtemp. it's not necessarily a fault of the IGBTs. It could be caused by a bad Vecon board.
Need Help!- Error on Fagor 8055 carving123 Commercial CNC Wood Routers 13 01-18-2010 08:44 AM
Fagor 4 axis post help jaangi Post Processors for MC 0 08-25-2008 04:39 AM
Following Error...Fagor 800t on lathe (X,Z axis) jime General Metal Working Machines 4 03-23-2008 05:50 AM
Fagor 800t Error 064 jime General Metal Working Machines 1 12-12-2006 12:40 PM
Fagor 8025M error 072 Mike Ball General Metal Working Machines 0 12-08-2006 11:13 AM
