Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Fagor Automation
Fagor Automation Discuss Fagor Automation products here.
Old 03-02-2009, 04:00 AM
pazdersk is on a distinguished road
8055 axis board error 2012
Hello
I have error 2012, this error gives when I don't have 24V on axis board. I check test hardware and there is problem with voltage some times its ok sometimes no (when i check power supplay its ok there is 24V on X10 plug). I put second card from other machine to cnc and it's ok for 2 days. right now i have this same error 2012 but in test hardware it's ok.
Do You have any idea were is the problem, sory for my english
Best regards
Mieszko
Old 03-02-2009, 06:35 PM
kcho is on a distinguished road
Did you ty to change the power supply? If you try with other Axis board maybe it could be an output. If it is in short circuit the protection hibrids may actuate. Check if the fails appear when you activate and specific element.
Carlos
Old 06-12-2009, 04:36 PM
Mert-G's Avatar
Mert-G is on a distinguished road
Dear Mieszko,
You say you checked X10 connector but you should check particular pins on this connector.
1) Pin 1 and Pin 20 must have +24V
2) Pin 18 and Pin 19 must have 0V
3) You should make a short circuit test for the cables from the mentioned pins to the power supply.
4) You should check if the cables are loose on the the relevant terminals.
Need Help!- Error on Fagor 8055 carving123 Commercial CNC Wood Routers 13 01-18-2010 08:44 AM
R2E4 SFP Board error arsenix Bridgeport and Hardinge Mills 5 08-06-2008 02:08 PM
Error code ? Replacement cost for a GNO master board? Skyshark Fanuc 3 08-21-2007 06:24 PM
Can I hook up a 3-axis board to a 1-axis board ? Redline Xylotex 7 02-09-2007 10:45 PM
Dainichi BX35 Fanuc 10T/F Input board error abselect Machine Problems, Solutions , Wireless DNC, serial port 12 05-23-2006 03:26 PM
