Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Fagor Automation
Fagor Automation Discuss Fagor Automation products here.
Old 02-18-2009, 10:06 AM
Captdave is on a distinguished road
File transfer 8025TG
I need a little help with setting up file transfer, this is the first time I have tried to use it. The software I'm using is Ezatrol, which is mainly used for Mazak controls but was told that it will work with other controls as well. I can send files to a device from the NC but can't receive them.
On OP mode 7, when I try to receive from a device it locks up an requires the control to be turned off then back on. It will do it even without the cable attached to the port. On a side note I can't get the DNC option to come on, not sure it needs to be on but I think that in the past it did come on but never tried to use it and can't be for sure.
Old 02-18-2009, 07:54 PM
Oregon Rich is on a distinguished road
Can't help much on file transfer. My 8025TG has a built in floppy drive. The only problem I've had is transfering a file writen on my computer then transfering it to the controller. What I do is write the program then transfer it via floppy to the computer to save it.
Oergon Rich
Old 02-18-2009, 08:32 PM
kcho is on a distinguished road
The dnc option itīs only for use with the windnc program. Download it from fagor automation web site the dnc software itīs free and you can transfer any files you want. I attached the link where you can download the soft.
http://www.fagorautomation.com/pub/d...ngl/windnc.zip
Carlos Cabrera
Old 02-19-2009, 06:13 PM
Thanks Carlos,
I would like to get the software working that I already have and use with the Mazak as opposed to using 2 different programs. If that isn't possible, I'll use WinDNC.
Old 02-19-2009, 08:37 PM
Yes you can use other software. But in fagor the dnc mode is only for Fagor dnc software. if you want to transfer a fiole with aother soft you must sincronize the transmision between the cnc and the pc. Honestly I recomend you to use the windnc. Itīs easy and you can see the program directoy from the pc. Itīs an online soft, you can send o receive without any syncronization. You have the rs232 communication cable?
Carlos Cabrera
Old 03-02-2009, 05:06 AM
bborb is on a distinguished road
Op Mode 7, you have to make sure DNC is OFF, then select OP Mode 2 or 3 depending whether sending or receiving. This is what I have to do to when using Procomm or HyperTerminal on my laptop.
Old 03-04-2009, 12:36 PM
Zebu Fellenz is on a distinguished road
Glad I found this thread. I've been working on getting a Fagor 8025 control to work with Mastercam post processing but it looks like the WinDNC route will be the way to go.
I'll grab a copy tonight and try it tomorrow.
Thanks,
Erik
Old 10-28-2010, 10:15 AM
Robert Taylor is on a distinguished road
PLC Program Upload Problems
How do you upload a PLC program to the PLC on the Fagor 8025?
I am fairly new to the Fagor world. I hear buzz words like "PLC 64", but I can't find such software available for download anywhere. I have used the WinDNC software to upload parameters, etc., but it does not allow me to upload a PLC program...
Need Help!- file transfer valleyron Mazak, Mitsubishi, Mazatrol 0 10-16-2008 05:29 PM
Need Help!- Mazatrol T Plus file transfer ict Mazak, Mitsubishi, Mazatrol 1 04-22-2008 11:28 PM
File Transfer roninB4 CNCzone Club House 3 08-27-2006 12:05 PM
file transfer axis overtravel Fadal 13 01-26-2006 10:55 PM
EIA file transfer grunemh Mazak, Mitsubishi, Mazatrol 0 12-02-2005 08:45 AM
