Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Fagor Automation
Fagor Automation Discuss Fagor Automation products here.
Old 12-20-2008, 11:18 PM
Captdave is on a distinguished road
Fagor 8025TG graphic display
I have never been able to get the tool path graphics to display. What is the key path sequence?
Old 12-23-2008, 01:21 PM
Fagor - Todd is on a distinguished road
Hi Dave,
I do not have an 8025 TG in front of me right now and that control has not been manufactured by many years, but it is easy never the less.... simply choose graphics in either the dry run or execution mode..... I recommend you start in dry run and execute your program in its entirety, then if it does not show-up on the screen...... hit the zoom sof key and then via the "+" or "-" keys zoom out until you see the graphics and then using the arrow keys key over in front of it.... zoom back down and press enter, this will reset your area definition for graphics and you can now see your graphic.
If you still have problems, call the Fagor Service department. If in the USA, call 800-423-2467 and ask for CNC service. If in Canada, call 905-670-7448 and ask for service as well.
I hope this kind of helps.
Sincerely,
Todd
Old 12-23-2008, 10:35 PM
I'll give it a try next week.
Thanks Todd for your help.
Old 01-15-2009, 12:11 PM
Worked like a champ, just a little clumsy to use.
Thanks again Todd.
Old 01-16-2009, 01:31 PM
The graphics always work on the old 8025's, I've never seen a graphic card fail on those in over 20 years.
But, I will say, the problem is that, the 8025's graphic program is a very old design, the new graphic programs in our modern CNC's are vastly superior in everyway including graphic set-up, resolution, color, etc..... if you like graphics, you'll like our newer controls considerably more.
good luck with the 8025 !!
Fagor 8025TG Oregon Rich Fagor Automation 1 01-27-2009 11:08 AM
Graphic Wraps for your cnc KustomKoncepts Camaster 1 11-23-2008 06:10 AM
Fagor Digital Linear Scales and Display Freddy4 General Metal Working Machines 2 10-26-2007 05:22 PM
Graphic display 10T guhl Fanuc 13 10-18-2007 09:39 AM
Fanuc graphic SAWMAN Fanuc 1 04-25-2005 11:38 AM
