Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Fagor Automation
Fagor Automation Discuss Fagor Automation products here.
Old 09-12-2008, 04:30 PM
Tom Curran's Avatar
Tom Curran is on a distinguished road
Retrofit Tree 320 with Fagor?
Hello, all. I have a Tree Journeyman 320. It's so solid and in such good shape, I think it worthy of a retrofit.
I have been looking at Fagor 8055 package. This seems like a great package. I would appreciate feedback from anyone using the control in the field.
Are there other controls I should take a look at for comparison? I say packages because I am a good mechanic, but I am not a computer whiz.
The machine is a vertical mill, servos on all three axes, no tool changer, no programmable spindle speed.
Thanks, Tom
Old 09-12-2008, 06:54 PM
gridley51 is on a distinguished road
I recently looked at a mill retrofit and compared the Fagor with a Siemens 802.The Siemens was $2000 cheaper and seemed to include more for the money.
Mark.
Old 09-12-2008, 11:07 PM
Tom Curran's Avatar
What I like about the Fagor is that I can load a DXF file into it and develop my program right there at the control. I looked at the Siemens site, but it wasn't very helpful. I may need to contact a sales rep. for my application.
Old 09-13-2008, 03:28 AM
The Siemens site is a bit of a disaster to navigate.I never seem to get around it the same way twice.You can download the 802D manuals from here.
http://support.automation.siemens.co...subtype=133300
Mark.
Old 01-27-2009, 11:01 AM
kcho is on a distinguished road
Hi Iīm Chrale sfrom argentine and Iīm a Fagor Oem. If you have to compare by prices a Siemens 802D or 802SL you have to look a Fagor 8035. The 8055 itīs a supirior control that have a conversacional move and a lot of options than the Siemens 802. If you need Fagor information please contact me.
Best regards
Carlos
Old 01-27-2009, 11:06 AM
The Siemens comes with a plc programme which you can edit.The Fagor comes without the PLC programme and no help from Fagor.
Old 01-27-2009, 11:48 AM
Becouse you donīt need any software to program it. And the in the manuals there is all the information you need. There is an plc model you can use for your first plc programming. And in the CNC you have all the tools to verified the plc there is a monitorizing page, even if you have to adjust and axis you have an osciloscope or a circle test.
And you have the WinDNC for free in the Fagor website. You could do the programm in your PC and communicate to the cnc or you could edit from the CNC keyboard.
Carlos
Old 01-27-2009, 01:09 PM
DareBee's Avatar
Monkeywrench Technician
DareBee is on a distinguished road
This statement is somewhat true.
Yes Fagor doesn't directly manufacture or support the PLC because it generally will be different for every application.
However Fagors "bolt-on" mill kit will have good support because it is mass produced and they are all the same.
On the other hand, when I have had Fagor tech out here (or on the phone) they have ALWAYS been able to help me sort-out/tweak my PLC settings and the PLC settings are directly available from the Fagor controller. Plain and simple because tech really knows their stuff and how it needs to integrate.
BTW- the few bucks saved by going to the 8035 is not worth it, the 8055 is vastly superior (especially for importing DXFs). For most jobs it is quicker to conversational program than it is to import a DXF anyway.
my .02
www.integratedmechanical.ca
Old 01-27-2009, 02:01 PM
But the DXF import itīs makes by the WinDNC program. So if you donīt use the conversational mode or other special feature you can use the 8035. The principal limitation is if you use an 8035M You only can use three axes + spindle you cannot connect a fourth axis. And the 8035T suports two axis + spindle. I put 8035 in several lathe, mills and machining center an it work perfectly. And the PLC program is very easy to do it.
Old 01-28-2009, 08:17 AM
DareBee's Avatar
I agree
But for the difference in price, the USB and the DXF abilities alone are worth it - not to mention all the other improvements.
  #11   Ban this user!
Old 01-28-2009, 09:25 AM
I hope Tom Curran decided to buy Fagor CNC. For me is the most reliable option than others CNC.
Best regards DareBee
Carlos
Old 01-28-2009, 01:42 PM
DareBee's Avatar
You as well Carlos
hardinge fagor retrofit Phoenix123 Fagor Automation 26 08-20-2009 12:28 PM
tree 2uvr-c tree mill willcofab Tree 1 06-11-2009 02:40 PM
Need Help!- camsoft retrofit to a anilam crusader retrofit bowlingmac CamSoft Products 44 07-24-2008 10:00 PM
CPU Fagor + LCD politecnica Brazilian CNCzone 0 03-04-2008 04:59 AM
Fagor DRO help hmc710 General Metalwork Discussion 1 01-30-2008 12:39 PM
