Page 1 of 3 123 LastLast
Results 1 to 12 of 32
Thread: Fagor 8055i Mill control Problems
    Sep 2006
    America
    We have a Fagor 8055i control retrofit on a Clausing knee mill. When we program it, the X-axis is always mirror imaged. For example, If I program a part in the 1st quadrant, the tool always moves to the second quadrant in X.
    It is almost as if the encoder or something is wired wrong or a parameter needs changing. Anybody have any experiance with this?
    I have tried G10 mirror image cancel at the beginning of the program and that does not alleviate the issue. Fagor, so far, has been no help at all. They say the axis movement is correct. The table position is moving negative and the CRT confirms this. What they do not seem to understand is that when the table moves negative, my tool position is positive of my zero. So when my program runs, it reads my positive moves and the tool is negative of my zero and engraving air. I hope this is not to confusing. I have given myself a headache.
    I am using Surfcam to program. The program will run on my Fadal with the Numatix control perfectly. It is just a simple engraving program.
    Any help is most certainly appreciated.
    Monkeywrench Technician DareBee's Avatar
    Jan 2004
    Stratford, Ont. Canada
    Let me ask you this.
    When you program the machine using the built-in icon/conversational screens, does it cut in the correct directions?
    If yes, changing machine parameters would not be very smart.
    Make a post processer for the machine with the X axis movement reversed.
    www.integratedmechanical.ca
    Sep 2006
    America
    Thanks for the reply.
    Yes, the control also cuts this way on the conversational side as well. When we had the retrofit installed, the tech just made sure all axes moved and he shagged out. We also had problems with the spindle drive, but we figured that one out. Do you have any more ideas? We are getting behind the ball a little bit. We use this machine to modify pistons and my machinist does not trust it. I do not think it is a training issue either. He went to the training classes in Chicago at Fagor and told me that their machines there moved correctly from the designated zero point with absolutely no issues. This is a first for me as well and I have been around CNC machines all my life.
    Jan 2004
    Sounds to me like the company/technician that did the install is/was negligent and should be held responsible for making things right.
    There should be a parameter in the PLC that can be changed to reverse the X axis servo, there is also a good chance that it could be done electrically.
    I have dealt with Fagor Canada technicians many times and they have been superb. I can't believe that Fagor USA won't tell you how to change the parameters, for shame.
    Sep 2006
    America
    Fagor tells us that the axis movement is correct and there is no need to change anything. This is the only gripe I have about the control. Do you have any idea where this parameter is located in the PLC?
    Jan 2004
    Sorry - I do not.
    Tell Fagor you don't give a flying *&^ if it is right, tell them you want to make it wrong and you want to know how.
    Besides, HOW do they know if it is right unless they send a technician out?
    Anyway, I am out of great suggestions for you now
    BTW - I currently have Fagor DROs on all my manuals and a Fagor CNC lathe. I have been very happy with Fagor and am budgeting for an 8055 controlled kneemill for the very near future (should be a lot more user friendly for 1-offs compared to the Fadal).
    Sep 2006
    America
    I appreciate the feedback. I think the knee-mill retrofit is excellant for one-offs. This, however, is my first experiance with Fagor. The other knee-mill retrofits I have used is the Proto-trak and the Mill Power by Accu-Rite. Both were pretty slick.
    Good luck and thanks for the help.
    Jul 2003
    New Zealand
    5th-axis
    I have a 3axis VMC with a Fagor 8055M controller.
    Attached are the details of the movement parameters that I could find for the 3axis of my machine.
    I'm not conversant with this area and are offering this info for you to compare which may help you to solve your problem.
    Attached Files Attached Files
    Sep 2006
    America
    Thanks Kiwi,
    I will check these and see if they match.
    Your help is appreciated.
    Sep 2006
    America
    Fagor 8055 problems continue
    The parameters that KIWI sent me did not match what was in our control. We changed the parameters to match and that did not help the issue. Has anyone had any similar issues with this control? The machinist who runs this machine is having to cheat up programs to work and I am afraid that this is going to cause some problems with scrap rate,etc. Not to mention the machinist has no faith in this control and is getting very frustrated.
    Dec 2003
    Is the table moving in the correct direction for standard cartesian coordinates?
    IOW if you have a spindle/quill that is fixed in the XY then the table should move towards you in the y+, away in the y-, move right for X- and left for X+.
    Sep 2006
    America
    The y axis movement is correct. When the table moves toward me, it is +. When it moves away, that is -. The only problem is in X axis.
    For example, lets say I have a 2 inch by 2 inch piece of stock. My datum is in the center of my stock. I want to drill a hole in the first quadrant at X.5 and Y.5 . When it actually drills the hole, the hole will be located in the second quadrant at X-.5 ,Y.5 .
    Thanks for your time,
  • Page 1 of 3 123 LastLast
    1. Fagor 8025M CONTROL help
      By ktk11 in forum General Metalwork Discussion
      Last Post: 11-10-2010, 03:17 PM
    2. Tooling for Bridgport fagor control CNC
      By star1280 in forum CNC Tooling
      Last Post: 11-20-2006, 01:39 PM
    3. thread cutting on fagor cnc mill 8055i
      By toolmaker_79 in forum Fagor Automation
      Last Post: 09-17-2006, 05:41 AM
    4. Fagor 8055i Post
      By jaangi in forum Post Processors for MC
      Last Post: 03-30-2006, 02:19 PM
    5. 8oo TG-1 fagor control
      By john zeigler in forum General CNC (Mill and Lathe) Control Software (NC)
      Last Post: 12-30-2005, 03:24 PM
