I found in search on Yahoo that a 8055M is a Fagor machine, is that correct? Do you know if the monitor is CGA or VGA? If CGA, I recently found a nice converter (Moncotech's MVC007) to convert that signal to use a VGA monitor, but the input is from a standard DB9 connector (or a DB15 connector with signals to pins as if they were from a VGA source but digital intead of VGA's normal analog signals). You'd have to know the 8055M's DB25 connector's pinout in order to use the converter.
LinkBack URL
About LinkBacks
