Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Fagor Automation
Fagor Automation Discuss Fagor Automation products here.
Old 10-16-2011, 07:02 PM
2kjettaguy is on a distinguished road
Fagor 8050 Missing Internal Programs
Hi Guys, I have a little CNC lathe with a Fagor 8050 control. The previous owner lost the backup battery and the control lost everything in memory inclusing all programs, parameters and the PLC program. I am slowly re-building the control. I've made it quite far. Parameters are set, I re-worked the PLC program using a program given to me. I'm currently working on some issues that the manual is referencing internal programs P999995, P999997, and P999998. I am missing these programs, provided by Fagor of course. The machine manufacturer is out of business.
Can anyone give me a copy of your programs P999995, P999997, and P999998 from your 8050? Even if your control - machine configuration differs. I just need SOMETHING to work with.
You can email me at evan@42draftdesigns.com
Thanks for any help you can provide,
Evan
Some additional info: My machine is an 8050 with an 8055 keyboard and monitor. It's a 2 axis CNC lathe with a turret. The programs I am missing are referenced here on page 129:
http://www.fagorautomation.com/pub/d...050tc_user.pdf
Old 10-21-2011, 01:28 PM
TAProwler's Avatar
TAProwler is on a distinguished road
Software Update Related
I checked out that page and it seems that those programs are related to software updates. Is that something that Fagor can provide?? Have you tried? They may be able to help you out with those routines.
I see their disclaimer about these programs not corresponding to a given software update - so maybe those programs are vendor created/provided and not available from Fagor.
Just a thought. Hope you get where you need to go. I've had a similar experience with an older model. I'd send them to you if I had that (or similar) model.
Good Luck.
R/Todd
NASA knee mill with Fagor missing electrical drawings dresda Knee Vertical Mills 1 04-20-2010 07:39 PM
8050 - 8055 file shareing conflictions. beno Fagor Automation 1 01-28-2010 10:17 PM
Need Help!- INTERNAL GROOVING BILLYD General Metalwork Discussion 3 05-20-2009 06:43 PM
M97 Internal Subprograms????? CAMCRASH G-Code Programing 6 03-24-2005 12:10 PM
Internal links Graham S Forum Questions or Problems 1 08-30-2004 07:53 AM
