Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Fagor Automation
Fagor Automation Discuss Fagor Automation products here.
Old 10-12-2011, 09:38 AM
Stupidav is on a distinguished road
Question Axis Removal
We have 7 Axis hooked up to a 8055M. One of the never used axis servos is dead, so not the "Reference All" won't work any more. The dead axis is one that has not been used since we got the machine, so we just want to disable / remove it, atleast for the time being.
What do I need to do to eliminate it so when the operator hits "Reference All" it will complete without any errors?
Thanks in advance for any assistance!
Motion Master 5 Axis Router.......Fagor 8055/C.......Surfcam Velocity 4.0 B189
Old 12-30-2011, 07:10 PM
CNCTech25 is on a distinguished road
You have to modify the general parameters.
On the general parameters screen you have all the axis listed (P0-P7) and each one had a value that represents the axis name. Which ever axis you wish to no longer use, simply change that corresponding axis to 0 and then reset the control (press shift and then reset) and you should no longer see that axis.
The installation manual has all the lists of which port relates to which parameter and what number is what label/name for the axis.
http://fagorautomation.com/pub/doc/F..._8055_inst.pdf
Z axis servo removal... help! Please badboy_matt Fadal 1 07-11-2011 10:17 PM
Okuma Z-Axis Motor Removal. RileyBRoo1 Okuma 1 06-18-2010 05:29 PM
Need Help!- VMC 15 z axis servo removal cncpilot Fadal 4 01-19-2010 09:50 AM
Need Help!- Fanuc OMD 4th Axis Removal Problem drgbt Fanuc 3 02-12-2009 01:34 PM
Newbie- 4th axis removal fokusco Haas Mills 5 06-10-2008 05:53 PM
