Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Fagor Automation
Fagor Automation Discuss Fagor Automation products here.
Old 09-03-2011, 03:39 PM
freightmaster is on a distinguished road
Fagor 800t control (help needed)
I have an ajax lathe fitted with the Fagor 800TGI control (only got it a few days ago)
I have never used a cnc lathe befor only a Bridgeport interact with TNC150, so I'm sure i'm doing somthing wrong! I am trying get to grips with the basic features but when programming a basic "canned turning cycle" and then hitting the start cycle button the lathe moves to the "begin point" and then says "executing" but does not move anywhere? I have read this section in the manual repeatedly but still I have no idear why it will not actually do anymore than move to the "begin point"
I should prehaps point out that the machine arrived with motors and drives removed and I have just fitted new motors and drives (correct replacment units) But as the axis all move properly via both jog and handwheels and it moves to the "start point" I'm at a complete loss
Any help greatfully received
Tristan
Old 09-10-2011, 10:35 PM
TAProwler's Avatar
TAProwler is on a distinguished road
Check the Jog Control
When this has happened to me on my 8025M, it has been because I mistakenly forgot to move the jog control off of the manual handwheel (or other non-manual override control position). Make sure it is selected to a manual override position 10-100%.
Hopefully it is as simple as this for you also.
R/
Todd
Old 09-21-2011, 03:21 PM
Wheels600 is on a distinguished road
Same here
I have a Chevalier 1840 with Fagor 800TGi and mine just started doing the same thing.
At first it was dwelling for a few seconds when changing direction during a part program and then the feed stopped working all together.
Handwheel works fine and rapid works as well....It rapids to the start of a program and then just sits there.
No alarms either
I hope someone out there has some advice.
Fagor 800T Tool saving tool set-up jime Fagor Automation 8 02-02-2009 07:53 AM
Following Error...Fagor 800t on lathe (X,Z axis) jime General Metal Working Machines 4 03-23-2008 04:50 AM
Fagor 800T calaban General CNC (Mill and Lathe) Control Software (NC) 1 10-15-2007 07:55 AM
Fagor 800t Error 064 jime General Metal Working Machines 1 12-12-2006 11:40 AM
Fagor 800t Postprocessor Unimatrix Post Processor Files 2 03-30-2006 01:23 PM
