Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Fagor Automation
Fagor Automation Discuss Fagor Automation products here.
Old 08-30-2011, 10:13 PM
Kiwi is on a distinguished road
Drive Error with Fagor 8055M
I keep getting Z Drive error when either stopping spindle when using manually or when starting a program when the spindle is already spinning.
First Screen Displays: 'External Emergency Activated'
arrow down.
Second Screen Displays: 'Drive Error : Axis Z
I am unable to clear either screen and only way to get out is to turn off and restart.
The Z Axis Module displays 0.E215. Don't know what error this is.
Any help appreciated.
ID:	141112   Click image for larger version
Old 09-05-2011, 09:39 PM
mzar is on a distinguished road
Normally its happened caused of positioning of spindle (sensor activated) in out of travel.
Old 09-05-2011, 11:07 PM
Hi mzar. I've since learnt that Error 215 is Power Bus Voltage Too High (hardware)
On further checking it appears the the Z drive errors when the motor is braking.
The program I'm running doesn't have any Z movements at all just X and Y.
Old 09-18-2011, 01:04 AM
Hi...I've download Winddssetup which is the Fagor software to monitor the Z drive. Made up a 9 pin cable to connect the drive module to my PC and getting ready to connect things up.
Any one been here before. Looking for any good advice.
Thanks.
BTW. I haven't studied the manual yet, I'd like to see something on the screen first.
Old 09-28-2011, 08:11 AM
Ed.Garza is on a distinguished road
Thanks.
Hi, I recommend you first to monitor the PLC Program, or if you already has monitor the drive send me the error code, Or in the Lcd Number Screen in the drive it shows the actual error too,
The emergency error comes up becuse its have a loop with the drives and the cnc control, and you have problems with the drive, check the power and enconder cables if the error appears when you start the machine and enable the drives probably the encoder signal have problems, other common problem its the servo break, should be 24+ and its a PLC signal with a Relay
Hope its helps you,
Old 10-03-2011, 05:18 AM
Originally Posted by Ed.Garza View Post
.. or if you already has monitor the drive send me the error code...
Hi The Error code is E215 (Power Bus Voltage Too High)
From what I understand (layman interpretation), a voltage is generated when the motor is free spinning (power off) which should be absorbed with a ballast resister. This doesn't appear to be happening and for some reason the Z axis errors.
Old 10-12-2011, 03:57 PM
Stupidav is on a distinguished road
Depending on the on your actual machine, it is quite possible that it is just the "Counter Balance" for the Z Axis. Some machines have an Air Cylinder with it's own Air Pressure Regulator so double check the Air Pressure Setting. Too high and it could happen when you travel down, too low could happen when you travel up, but it could be the oppisite, again depending on your machine. Other machines have an actual "Counter Balance" weight, make sure it is still attached or for that matter make sure that how it is connected is well lubricated.
One thin to try just to simplifiy your trouble shooting is, in your program prior to stopping your Spindle, do an "G4K500", this will add a delay prior to stopping the spindle.
That Drive Error is usually because the Drive is trying to the oppisite of what it just was to it needs to "Disapate" the excess energy, which is typically what the metal box on the out side of the control is, Dynamic Braking Modual. Unused energy is attempted to be fed back on to the "Bus" so the other drives can utilize it, but if it doesn't get used generally it is "Dumped" onto the resistors in the Dynamic Braking Modual. If it can't do this than the drive Errors out. So assuming the Counter Balance isn't the issue, make sure that the Dynamic Braking Modual is free and clear of any metal shavings, which can short out the resistors not allowing the energy to be disapated on them.
Hope this helps. (sorry for the spelling, in a hurry)
Motion Master 5 Axis Router.......Fagor 8055/C.......Surfcam Velocity 4.0 B189
Old 10-12-2011, 04:44 PM
Originally Posted by Stupidav View Post
....Other machines have an actual "Counter Balance" weight, make sure it is still attached or for that matter make sure that how it is connected is well lubricated....
.....One thin to try just to simplifiy your trouble shooting is, in your program prior to stopping your Spindle, do an "G4K500", this will add a delay prior to stopping the spindle...
......make sure that the Dynamic Braking Modual is free and clear of any metal shavings, which can short out the resistors not allowing the energy to be disapated on them....
The machine is a Vertical Machine Centre which has an actual counterweight which is suspended on two link chains over sprockets. I will check their condition.
I have tried using G04 with various times without success. I've also used various stepped speeds with time delays between without success.
I do feel the fault is, as you outlined in your third paragraph.
We have swapped the Z and Y Drives over and now the Error Fault is Drive Y which indicates the fault is in that Drive Unit.
Thanks for your input
Old 10-12-2011, 09:54 PM
If you swapped drives around and the problem followed that drive, the drive is the problem.
Do double check the counter balance, and make sure that it moves freely. Excess strain either from lack of lubrication / stiff chains or stuck Guide Sprockets, or even the lack of the counter balance, can cause this issue over time.
Old 10-14-2011, 06:29 PM
If you swapped drives around and the problem followed that drive, the drive is the problem..
Before I order a new drive, has any one have any suggestions on what part of the drive may be failing.
Fagor 8055m and renishaw sp2-1 mwyss Fagor Automation 0 05-13-2011 04:44 PM
Just IN- Creating a 90 degree arc. FAGOR 8055m mehtalmann CNCzone Club House 0 04-12-2011 12:25 PM
Mastercam post for Fagor 8055M jaangi Post Processors for MC 12 07-27-2010 05:49 AM
Need Help!- FAGOR 8055M MASTERCAM V8 POST NIKEIME Post Processors for MC 1 09-17-2009 10:43 PM
FAGOR 8055M 3Axis Controller Kiwi Fagor Automation 8 11-16-2004 03:53 AM
