Page 2 of 2 FirstFirst 12
Results 13 to 16 of 16
Thread: Convert 8025T to PC Based Controller
  1. #13
    Jul 2008
    The best thing to do with an 8025 is upgrade to the 8035..... 8025 was our ugly duckling work horse control back in the 80's and early 90's, but it has run its course. Had a great run though.... those things were indestructable.... they'd get a little ugly with that old amber phosphorus monitor burn-in, but they just kept working.
    But, we do offer a modern CNC upgrade to it, callled the 8035, which was specifically created to be an upgrade control from the 8025. It maintains the same size as the 8025.... and we supply it with the adapter cables. Hence, it is a 1 day retrofit. It just slides into where the current 8025 is, you plug in the adapters, converter some parameters and you're done. The 8035 utilizes a modern user interface (based upon the popular G-code sides of the 8055 series) and has a lcd color monitor.
    These are sold by our Service Department and I know they have a special trade-in price right now.....for more information, call 800-423-2467 and speak with service department about this upgrade.
  2. #14
    Feb 2006
    australia
    hi; after trying for an answer since I posted the last request in this thread,(6 months) the only thing Ive got from Glentek was a email saying that they forwarded the request to the
    supervisor, looks like that this mob is very busy..... Can some one please helpmme with this?
    thank you
    Mariano
  3. #15
    Dec 2003
    Normally you can replace the older DC motor drives with modern A-M-C versions, they offer all models of DC and BLDC, where the BLDC will run a DC brushed also, with BLDC you have the option of replacing the motors with BLDC type at a later date if needed.
    The 8025 usually uses ±10vdc control which is compatible with the A-M-C.
    Feb 2006
    australia
    Hi ;Thanks for the answer.
    The problem is that I bought some drivers and can't use them until I know a bit about them, (pinouts, etc), and the people from Glentek are not very helpful
    regards
    mariano
  1. Controller based on STK6712BMK4
    By AleksMK in forum Open Source Controller Boards
    Last Post: 06-03-2010, 01:53 PM
  2. Convert MillPwr->PC based control?
    By arsenix in forum Bridgeport and Hardinge Mills
    Last Post: 05-27-2010, 05:29 PM
  3. Replies: 4
    Last Post: 11-07-2009, 12:03 AM
  4. Masima PC-BAsed CNC controller
    By kevin9348 in forum Product and Manufacturer Announcements
    Last Post: 04-20-2009, 04:59 AM
  5. Convert to PC based
    By Arcticfox46 in forum CNC Wood Router Project Log
    Last Post: 08-10-2007, 09:05 AM
