Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Fagor Automation
Fagor Automation Discuss Fagor Automation products here.
Old 11-21-2010, 12:20 PM
RB1 RB1 is offline
RB1 is on a distinguished road
engraving with 8040
Hi, Just bought a VMC, 2005 era Micro-cut Challenger 2412. THis unit has 8040 controls (will not be powered up for a couple of weeks to be able to check exact version).
I have a long learning curve, but Fagor is sending out a training DVD and I have the original manuals.. so that will be my future studies...
I have ALibre for CAD, and have not decided on anything for CAM yet, and will have to as the programs I need to run require cad / cam in addition to the conversational programs.
My questions are:
Does the 8040 have an engraving option, or would my options be to engrave thru cad/cam?
thanks alot, will have many newbie questions and very much appreciate the knowledge here!
Old 11-25-2010, 11:53 AM
RB1 RB1 is offline
I do not have the machine yet, should be here next week, but Fagor Automation sent me a training DVD that is quite helpful, and they quickly mentioned and showed the screen for engraving, so I am pretty excited about that. Actually, looking at the whole conversational interface they have... I am optimistic that this was a VERY good choice for me.
I would like to add a probe to it, and found one at:
Wildhorse Innovations - The DRO-350 Store - Econo-Probe 3D Probe & Tool Height Setter
I know it is not a renishaw / marposs but if I can wire it in to talk to the Fagor, then it will be a step in the right direction.
Anyone with experience here?
Old 12-13-2010, 01:36 PM
Fagor - Todd is on a distinguished road
Hi RBI,
Yes, we have an Engraving Cycle option. It may already be turned on with your 05 machine, or not. Call and talk to the Fagor service department at 800-423-2467 if you discover it is not turned on, but would like it too. (As a note, to access on the conversational side of the CNC, press the "pcall" key, it will show the cycle in the directory if you do.
In regards to basic probing, this is a standard feature of all Fagor CNC's.... G75.
In addition, optionally, you have a library of Probing canned cycles plus Digitizing cycles available. To see if this were turned on prior, on the G-code side of the CNC, go into the diagnostic mode and then into software configuration. It will show Probing and Digitizing if they are turned on.
Hope this helps.
Todd
Fagor 8040 Lathe Threading K&T EB Fagor Automation 1 01-19-2010 08:02 AM
Fagor 8040 Controller cjels Want To Buy...Need help! 3 02-20-2009 12:34 AM
Alarm 60 ECP Bus error 8040 on Okuma LR15 Lathe mohammadali Okuma 3 01-22-2009 05:16 AM
Fagor 8040 control cjels General Metalwork Discussion 5 07-15-2008 06:46 AM
Fagor 8040 Dxf Problem Mert-G General CNC (Mill and Lathe) Control Software (NC) 4 09-29-2007 04:51 PM
