Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Fagor Automation
Fagor Automation Discuss Fagor Automation products here.
Old 06-26-2010, 08:14 AM
Captdave is on a distinguished road
G41/G42 on 8025TG
I have her back up and running again everything seems to be working well. I have always used this machine for second ops and threading and have never had any luck getting the G41/G42 for TNR to work. If I have needed to compensate for it I just added the TNR to the desired radius and let it fly.
I'm sure its in the way I'm programming it (0r where) and the Fagor manual is written so poor that my simple little mind cant get around it.
If some one could please post a sample block of a program with the correct format that it would be helpful.
Old 07-16-2010, 09:04 PM
No one uses cutter comp while turning?
Old 07-17-2010, 08:49 AM
dek dek is offline
dek is on a distinguished road
go into tool offset table
r is for tool radius
f is for location code
location code is found in user manual
make sure you on a front loading toolpost or rear for the codes
Old 07-18-2010, 09:50 PM
Yep did all that too!
Old 07-19-2010, 01:39 PM
dek dek is offline
also the tool must be called up in the line with g41 or a previous line and dont for get to cancel with g40
i.e T1.1 F.01
G41 X10 Z0
Old 07-20-2010, 01:59 PM
N200 G92 S2800 T08.08 M3
N210 G41 G96 S500
N210 X0 Z0
N220 G1 X-.625 F.004
N230 G39 R.070 X -.625 Z0
N240 X-.625 Z-1.00
N250 G2 R.050 X -1.205 Z -1.000
N260 X-1.205 Z-1.150
N270 G0 Z.100
Is this correct?? Tool tip 5 in register, cutting on the operator side M3
Old 07-20-2010, 03:19 PM
dek dek is offline
if it is a front mounted toolpost the code is 3 . The code 5 would be for rear toolpost
also if front mounted toolpost you x should be +
Old 07-21-2010, 05:04 PM
Its' a gang tool lathe so the tools can work on either side of the spindle by just turning them up side down. The example I gave was for a tool cutting on the front/operator side of the spindle.
My manual shows 5 for front/operator side and 3 for rear tools as copied from the manual below:
"• F3 would be an outside turning tool on X+ or a boring bar on X-"
"• F5 would be a boring bar on X+ or an outside turning tool on X-"
Is the rest of the code correct for use with TNRC?
File transfer 8025TG Captdave Fagor Automation 7 10-28-2010 09:15 AM
need help 8025TG screen rolling Captdave Fagor Automation 5 05-21-2010 12:20 PM
Hardinge/Fagor 8025TG error 099 m-tables lost Tinmuk Fagor Automation 0 07-25-2009 11:38 AM
Fagor 8025TG Oregon Rich Fagor Automation 1 01-27-2009 10:08 AM
Fagor 8025TG graphic display Captdave Fagor Automation 4 01-16-2009 12:31 PM
