Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Fagor Automation
Fagor Automation Discuss Fagor Automation products here.
Old 05-13-2010, 09:04 AM
Captdave is on a distinguished road
need help 8025TG screen rolling
I have a Fagor 8025TG control and the screen has started to roll vertically like an old TV set from the 60's. Is there an adjustment pot to correct this and if so where is it located?
Old 05-20-2010, 09:53 PM
JP Hardinge is on a distinguished road
I was told at Fagor the screens can presently be fixed. There is an LCD replacement on eBay. Don't know how well those work.
Would be nice if it was just an adjustment.
I just got my second machine with an 8025 control.
Old 05-21-2010, 10:50 AM
I would be interested in your progress with the monitor repair Dave, as I know sooner or later I will be rolling down that road.
The guy on eBay wants way to much money IMO for what he's selling. I don't know why another monitor could not be adapted to work. Here's some info on swapping out the Fagor with a universal:
"For the 8025 we use our universal 8.4" LCD monitor. Fagor says that their monochrome monitor is an 8" monitor, but it is actually a 7" Monochrome. Our LCD upgrade kit bolts on to the original frame (remove the CRT and electronics and screw on the new LCD where the CRT use to be). Our LCD is a little large, but there are size adjustments to reduce the viewable area to from 8.4" diagonal to 7" diagonal. We provide the video adapter cable, you may have to wire the power. The information that I have for the monitor is (which is no problem for our univeral LCD)-Display surface: 146 x 119 mm.Vertical sync: 50-60 Hz Horizontal sync: 19.2 KHz Note: Our LCD is setup for green, not amber. If you really prefer amber, we can setup to do that, but the amber is more of a redish amber."
Maybe a monitor such as this one would work:
http://www.qualitymobilevideo.com/LCDM84VGA.aspx
Old 05-21-2010, 11:58 AM
JP- thanks for the info. I'm not going to jump into a repair at this point since it only rolls for a while when its warming up. I do second OP work with this machine so it doesn't run everyday. I'll live with for now and see what pops up down the road.
Old 05-21-2010, 11:59 AM
I forgot to ask but is the link to a screen that the EBay guy recommended or one you did some research on yourself?
Old 05-21-2010, 12:20 PM
The link was not recommended, I was just searching for options.
A universal display is what the eBay guys has and is a lot of money. I just think there are other ways to skin this cat for much less.
File transfer 8025TG Captdave Fagor Automation 7 10-28-2010 09:15 AM
Hardinge/Fagor 8025TG error 099 m-tables lost Tinmuk Fagor Automation 0 07-25-2009 11:38 AM
Fagor 8025TG Oregon Rich Fagor Automation 1 01-27-2009 10:08 AM
Fagor 8025TG graphic display Captdave Fagor Automation 4 01-16-2009 12:31 PM
Rolling your own Toroidal speed33317 General Electronics Discussion 4 11-24-2004 01:59 AM
