Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Fagor Automation
Fagor Automation Discuss Fagor Automation products here.
Old 04-21-2010, 01:32 PM
dek dek is offline
dek is on a distinguished road
programing G68 on fagor controller
could use someone,s help again
its a front toolpost lathe
the program ive put in consists of arcs and straight lines, the lathe has no graphics just a dry run .Please can someone see where i,m going wrong
N0 G97 G70
N10 G53
N20 F0.04 T4.4
N30 G92 S600
N40 G96 S650 M42 M3 M8
N50 G00 X17.5 Z0
N60 G68 P0=K7.875 P1=K0 P5=K0.1 P7=K0.2 P8=K.003 P9=K0.02 P13=K95 P14=K160
N62 G00 X17.5 Z2.0
N65 M02
N70 M30
N95 G02 X8.0 Z-.0625 I0 K -.0625
N100 G01 8.0 Z-2.625
N110 G03 X8.5 Z-2,875 I.25 K0
N120 G01 X8.75 Z-2.875
N130 G02 X11.0 Z-4 I0 K-1.125
N140 G01 X11.0 Z-6.75
N150 G03 X11.5 Z-7.0 I.25 K0
N160 G01 X17.5 Z-7.0
If i delete line 160 and alter p14 to 150 the dry run seems to work but soon as i re-input it error 004 (G02 G03 G33 is active) comes u
Old 04-21-2010, 03:19 PM
beege's Avatar
beege is on a distinguished road
You are aware that N62 says GOO and not G00?
Also, try a G01 X8.0 Z0 at N90 (between N70 and N95)
Old 04-21-2010, 06:17 PM
dek dek is offline
yes i did go over it but missed that one,I think ive tried what youve said i will give it a go.
Old 04-22-2010, 11:13 AM
dek dek is offline
tried it in work today still the same ,i typed in the example prog from the manual with the same result,the manual gives a rear toolpost prog so ive had to alter the G02 and G03
Help needed on FAGOR controller CNC_Geek G-Code Programing 5 10-09-2011 02:42 PM
Fagor 8040 Controller cjels Want To Buy...Need help! 3 02-20-2009 12:34 AM
Can anyone help programing a Fagor PLC 64? wyobmf G-Code Programing 3 06-12-2007 12:13 PM
CRC programing with an old Fanuc 11M controller Moparmatty G-Code Programing 4 02-08-2005 09:10 AM
