Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Fagor Automation
Fagor Automation Discuss Fagor Automation products here.
Old 03-25-2010, 02:24 PM
luiso is on a distinguished road
How can i configure a FAGOR 8020 MG
Hello
I have a CNC Fagor 8020 MG and it don't allow me operate it. I can set the parameters but it doesn't work.
Old 04-13-2010, 11:29 AM
Odin M Yggdrasi is on a distinguished road
Originally Posted by luiso View Post
Hello
What kind of machine is it attached to?
Have you checked for the presence of a PLC in the system?
Old 04-20-2010, 07:35 PM
Fagor - Todd is on a distinguished road
The 8020 does not have a PLC, it instead utilized dedicated inputs and outputs...... your control will operate if you jumper pins 14, 15 & 16 on I/O 1 to 24vdc and have 0vdc on the reference inputs of the I/O 1 connector..... these are the NOT E-stop in, NOT Feedhold & NOT cycle stop inputs..... thus beware if you actually do that.
However, all parameters must be set accordingly as to the machine configuration to have good axes movement..... dependant on where you are, you should contact a local Fagor office to find out where the best help for you is located. This link will help direct you to the appropriate phone #'s. http://www.fagorautomation.com/_bin/red_comercial.php
I hope this is helpful and good luck !
Todd
FAGOR 8020-GP CNC PARAMETERS Geo@az Fagor Automation 5 02-15-2012 07:12 PM
Alguno tiene experiensa con el sistema Fagor 8020-GP CNC Geo@az Spanish CNCzone 0 03-12-2010 09:04 AM
Cannot configure the drive. LBodnar Granite Devices 23 01-26-2010 07:49 PM
Possible to configure without GD Tool? pixpop Granite Devices 6 12-22-2009 11:13 AM
configure run button xtihc Mach Software (ArtSoft software) 1 05-25-2006 04:57 PM
