Fagor problem solved.
Okay fellows I have solved my
CNC programming issue. After several weeks and going over and over through the entire programming manual and not having any experience with CNCs before, my
CNC punching machine is up and running again. However the code 094 Parity error T, G53-G59 is still coming up at the start up.
The reason I couldn’t enter new programs was because I had the
cnc memory locked therefore it would’ve not let me run the machine in automatic mode.
Now, I don’t know if the same parameters I used for the Fagor control would work for the GE MCI control but I guess I could send you the programming format as an attachment. There are 26 pages.
