- 8055T - SPD 1.35 spindle drive error 307 - dc bus voltage low
Hi all,
anybody has a clue or solution for Error 307 - dc bus voltage low?
the spindle drive of a lathe ends up with this error.
x,z drives work properly. when connecting the drive by rs232 to the pc, the dc bus voltage is always the same 387V even if the other drives show the correct voltage.
any hint will be greatly appreciated.
Hi all,
any hint will be greatly appreciated.[/QUOTE]
- You may not post replies
- You may not edit your posts
Forum Rules
