- fagor 8025T help
fagor 8025T help
Hi everyone
I have a fagor 8025T retrofitted to a LeBlond tape lathe. The connections seem to be standard to the instalation Manual . However I did not use it for a while and the memory battery went flat. It has lost all its parameters and Mcodes I have tried the unlock codes ect in the manual however Have had only small success in getting the machine to work. Does anybody have a similar lathe with the decoded m functions and parameters I can copy and load to the controller
- fagor 8025T help
- You may not post replies
- You may not edit your posts
Forum Rules
