Need Help! Fagor 8055 Error "#36 No START. MOTOR HEAT SWITCH TRIGGERED"
Results 1 to 3 of 3
Thread: Fagor 8055 Error "#36 No START. MOTOR HEAT SWITCH TRIGGERED"
    Jul 2009
    Angry Fagor 8055 Error "#36 No START. MOTOR HEAT SWITCH TRIGGERED"
    Mar 2008
    Argentina
    Default Re: Fagor 8055 Error "#36 No START. MOTOR HEAT SWITCH TRIGGERED"
    PLC error : Maybe you have an overheated motor or a broken wire.
    Carlos Cabrera
    May 2015
    N, Ireland
    Quote Originally Posted by wazie View Post
    I am guessing this is a machine builder ( Lagun) error code.
    I looked for resets in the control cabinet. Reset the breakers.
    Looking for ideas of where to go next.
    Hi I'm not sure if it helps but I had a problem on my chic poncho lathe.8055. Turned out there was excessive ohms on the drive motor caused by a problem thermister in windings. The problem was sorted by placing a resister on affected pin out to drives to fool system alarm disappeared but now have no motor overtemp alarm. It's a price to pay for a working machine
