- Fagor 40i-TS electronic controller stuck in Boot screen.
I have a Harrison centre lathe fitted with a Fagor digital readout/speed controller. The unit when, power is switched on displays a picture of a penguin and a message stating Booting system, please wait"
Can anyone help to reset the unit?
Re: Fagor 40i-TS electronic controller stuck in Boot screen.
On the backside there is a hole that has a reset button in it that you can access with a small screw driver. If that don't work sounds like software got corrupted or bad hardware.
Sent from my Pixel XL using Tapatalk
Thanks for that, I have tried the reset button and the same message comes back up.
- You may not post replies
- You may not edit your posts
Forum Rules
