Hello,
I have a CNC that uses a FAGOR 8025 controller and I am using WinDNC to send .PIM files from the PC to the CNC.
I am using a PC with windows 7 and a USB-RS232 connector.
I have managed to put the WinDNC connecting with the PC and have already moved files from the CNC to the PC.
The problem is when I try to execute an infinite cycle with a .pim file created at the PC.
The following error message appears "there is no room for the infinite program buffer" which is the error 45.
Any idea why is this happening?
Here there is the code that I am trying to send:
%09997
N0 G0 Z0
N10 G0 Z-80
N20 M30
Thank you very much in advance.
Regards,
Simão Nóbrega
