- Need Help!- Fagor CNC Running single block once
I am using Fagor CNC machine. Mode: 8040T
Now if I run a program its run for one line each time.
LIke:
G00 X0 Z0.........................1
G00 X-3 Z-4......................2
G01 Z-5 Z-5.......................3
G00 X0 Z5............................4
If I press the cycle start it start to work line 1. Then stop. But in screen "In Execution" is still displaying..
Then if press cycle stop, then reset, then cycle start again then run for line: 2. again stop..
As far I know this behavior should be in single Block mode. But the machine is not in single block.
Please help how can I solve the problem.
Re: Fagor CNC Running single block once
Are you pressing single block button again before you execute?
Check following error when the machine are in execution. maybe you have to tune the servodrives.
Carlos Cabrera
Yeah sounds like your machine is hanging up trying to get to position. Following error probably your problem. Might be an encoder fault.
- You may not post replies
- You may not edit your posts
Forum Rules
