- Need Help!- Fagor ethernet connection
I have a CNC lathe with a Fagor 8055T control
I need to connect via an ethernet cable using WinDNC 5.2
Can anyone help me with the settings on the WinDNC software and the parameter settings on the CNC
On my PC I am running Windows 7
Graham
This link describes an step by step procedure to establish a TCP/IP networking with 8055 systems.
http://famatechnology.com/cms/wp-con...05/network.pdf
Re: Fagor ethernet connection
Hi
Thanks a lot will give it a try
Regards
Graham
Hi
Thanks so much works perfectly big thumbs up
Regards
Graham
- You may not post replies
- You may not edit your posts
Forum Rules
