- looking for the mastercam V8 post 8055
Hello all
we have just got a new lathe in the shop with the fagor 8055i. All the other lathes have a fanuc control on them, so all my programes have been posted from mastercam V8.
So I would like to get the proper post for the fagor control so I can just re-post my programes and run them.
I have been using the fanuc post and just editing them then using cimco editor to save as a .pit file.
It would be nice to be able to post it and not have to do a bunch of editing.
If anyone has a copy that they are willing to shair that would be grate.
Search
After a quick search (little box in the upper right of this page), I found these threads, which might have some useful info for you:
http://www.cnczone.com/forums/post_p...or_8055_i.html
http://www.cnczone.com/forums/master...r_machine.html
http://www.cnczone.com/forums/fagor_...rcam_post.html
and there are many others. I just searched for "mastercam 8 fagor" and got pages of hits.
Also, most CAM software companies will write you a post processor for whatever machine you need (if they don't already have it available on their website). You might have to send them a copy of the programming manual for the control you have. I know its true for the two that I use (SheetCAM and BobCAD-CAM). Check with MasterCAM (or maybe you already have) - if not, it appears that the process all starts here:
http://www.mastercam.com/support/Posts/Default.aspx
Good Luck,
Todd
Re: looking for the mastercam V8 post 8055
- You may not post replies
- You may not edit your posts
Forum Rules
