Connect PC to Fagor 8055 - Page 2
Page 2 of 2 FirstFirst 12
Results 13 to 24 of 24
Thread: Connect PC to Fagor 8055
  1. #13
    Dec 2011
    Quote Originally Posted by jbrookes View Post
    also please let me know the operating system you are using. I have XP.
    If you use Fagor's WinDNC, WinXP is good. I've run WinDNC on Win98, WinXP, Vista, Win7. No issues (that is if you dont consider not being able to uninstall on Win7 a issue...)
    I used to use DNC30 which is DOS based.
    WinDNC is your best bet to get a connection from control to PC etc. You can use the default serial parameters on the control since they're set for Fagor's protocol. All you would have to do is set up a profile in WinDNC for the connection and define the control model and match the baudrate to that of the control.
  2. #14
    Jun 2006
    EGYPT
    could anyone post the right pi assignment for the the rs232 cable?
  3. #15
    Dec 2011
    Quote Originally Posted by sting View Post
    Simplified connection is 2 to 3, 3 to 2, 5 to 5 and on each subD connection jump 4, 6, and 8 together. This will work for all 8055 controls (except for Eprom style, very old 8055 that came out right after the 8050)
  4. #16
    Mar 2005
    Texas
    Quote Originally Posted by CNCTech25 View Post
    Latest Windnc(from Fagor Spain) on XP. Serial port parameters on PC and CNC match. Upon start up of Windnc. screen titled 4456.txt has column on left with 3 .txt files and says local. Bottom of screen has black bar with C: in it. Red bar with what looks to be a network icon below the black bar. The only active things are the 3 file icons in the left column. Opening them just opens an empty page.
    Not 100% sure that the cable is correct. Only know that it works with Fanuc and very old 8020m control.
  5. #17
    Mar 2005
    Texas
    Quote Originally Posted by alphonso View Post
    Problem solved. Corrupted installation of Windnc. Reinstalled and everything works as it is supposed to.
  6. #18
    Mar 2014
    help 8055tc with eprom I missing, cabel diagram, machine parameter
  7. #19
    Registered rui.orfao's Avatar
    Jul 2014
    Default Re: Connect PC to Fagor 8055
    for 8055 with eprom or 8050 and older cnc fagor controls, the pin out is 2 to 2; 3 to 3; 5(pc)to 7(cnc); at cnc side join 5-6-9; at pc side join 8-6-4.
    set serial comunication parameters to their default value (hit initialize softkey) or try the comunication with windnc at 9600boudrate
    kind regards
  8. #20
    Jul 2014
    hi
    for 8055 eprom series or 8055 and older cnc fagor controls, the cable pinout is 2 to 2; 3 to 3; 5(pc) to 7(cnc); join 4-6-8 at pc side; join 5-6-9 at cnc side;
    try thye comunication at 9600 baudrate all other parameter to default.
    kind regards
  9. #21
    Mar 2014
    this not Work for me
    this Works on my 8055 tc control whit Eprom --- I am happy now .. remeber hit initalize softkey
    kind regards
  10. #22
    Mar 2014
    Quote Originally Posted by rui.orfao View Post
    hi
    kind regards
    i am happy now it´s Works whit windnc 9600 baud .
  11. #23
    Aug 2011
    Portugal
    Hi, Greatings from Portugal
    Need help with ethernet communication on windows 7
  12. #24
    Jun 2006
    Instructions I got for setting our 8055 up
    TCP/IP HARD DISK & ETHERNET SETUP
    FAGOR 8055
    ( Direct to a PC using a crossover cable )
    ( The IP addresses used are for example purposes only, other IP addresses may be used )
    CNC PARAMETERS
    P1 = 0
    P2 = FAGORCNC (ANY NAME TO IDENTIFY THE HARD DISK)
    P22 = 1 (Sets communications to RS232/Serial 2 and Ethernet , disables RS422)
    P24 ( DIRIP ) = 10.1.1.2 ( IP Address of the CNC )
    P25 ( NetMask ) = 255.255.255.0 ( Must be set in PC as Subnet Mask )
    P26 ( IPGateway ) = 10.1.1.1 ( IP Address of the PC ) or ( IP Address of the Server )
    P27 ( IPSWDNC ) = 10.1.1.1 ( IP Address of the PC the CNC will use for DNC )
    WINDOWS XP SETTINNGS
    1. CLICK ON “Control Panel”
    2. CLICK ON “Network Connections”
    3. CLICK ON “Local Area Connection”
    4. CLICK ON “Internet Protocol(TCP/IP)”
    5. CLICK ON “Properties”
    6. CLICK ON “Use the following IP address”
    7. Enter in the IP Adress “ 10.1.1.1
    8. Enter the Subnet mask “ 255.255.255.0 “
    9. CLICK ON “OK”
    To Drag and Drop files from PC to CNC
    1. Open “WINDOWS EXPLORER”
    2. In the ADDRESS line type in FTP://10.1.1.2
    3. CLICK ON “Disk”
    4. CLICK ON “prg”
    ( This will bring up a list of the programs in the CNC )
    To create a shortcut on the DESKTOP of your PC
    1. CLICK ON the icon in the address bar of explorer that is right before the ftp://10.1.1.2 that
    you previously typed in , drag that to your desk top and drop it.
    WINDNC 4.0 (and higher) Connection
    In SETUP -
    1. Double Click the TYPE window and select “NETWORK NODE”
    2. Connect on Startup – double click the box to enter “X”
    3. Double Click the IP ADDRESS window and type in “10.1.1.2”
    ( This allows the WinDNC program to send and receive files just as if a serial cable were connected, just MUCH faster.)
