- SIEMENS 828D 3D MACHINING ISSUES
Not sure if anybody else has these issues
but whenever i run a parallel tool path, this stupid controller always throws an error on a arc movement somewhere deep in the code even with cycle832 in there , i never have this issue with the fanuc on the same code , is there a setting somewhere that i am missing not sure , but it is driving me nuts, i am programming with HSMWorks using the 840d post, and have played with tolerances of the cuts etc but nothing is working
help would be appreciated
- You may not post replies
- You may not edit your posts
Forum Rules
