What you showed was the output from your post processor. Look at the N0010 line. Your post processor is the MP-1000-thc.scpost. The post is found in the program files folder under Sheetcam, posts. Open it with notepad and and change the refdistance to 99999 also.
I opened the post on my machine and it looked like this:
dist = 9999999
refdistance = 99999* scale
--Put your switch offset value here
switchoffset =.052
lastz = 0
end.
This is also where you set the switchoffset(from earlier post) for your cut height. Change the .052 number to correspond to your needs.
Good luck
Mike
LinkBack URL
About LinkBacks
