Page 2 of 2 FirstFirst 12
Results 13 to 14 of 14
Thread: 4x4 Apc machine
  1. #13
    Jul 2007
    Have you adjusted the Tip Volts on the Torch Height Controlller? You should give our technial support team a call at 903-569-3190.
  2. #14
    Feb 2009
    Quote Originally Posted by Parm473 View Post
    I have an ez router 4x4 apc plasma machine i have no problems cutting .125 mat i'm trying to set up to cut .187 mat the machine has a miller spectrum 375 plasma torch that i'm using its not cutting all the way through the mat in spots and is leaving alot of slag when it does cut through, anyone have suggestions on amps ,tip volts, and speed i should be using thanks
    Your user manual for the Miller Spectrum 375 should have charts listed to give you a basic guideline of input parameters needed to cut 3/16" plate. I don't know the exact model number you have (there are a few listed for the 375), but using page 21 in this user's manual: http://www.millerwelds.com/om/o225216g_mil.pdf
    I come up with the following:
    40 inches/minute @ 27 amps
    or
    26 inches/minute @ 20 amps
  1. saleCNC laser engraving machine and CNC woodworking machine
    By zhangrui1588 in forum General Laser Engraving & Cutting Machine Discussion
    Last Post: 05-08-2011, 04:54 PM
  2. cnc router/CO2 laser machine/cnc plasma cutting machine
    By cncengraver in forum Chinese Machines
    Last Post: 06-25-2010, 10:48 PM
  3. Replies: 1
    Last Post: 11-20-2009, 07:03 PM
  4. Deep Groove Taig machine would it be a good starter machine
    By Fritzie15 in forum Taig Mills & Lathes
    Last Post: 09-20-2007, 10:37 PM
