Originally Posted by
curlyweld
If you think it's just dragging when moving from cut to cut then you need to set you travel height in sheet cam. I set mine at 1.5 inches and has always been high enough to clear small tip ups. I forget just where in sheet cam it is, I think it says Z = height and there is a box for you to set your travel height. If you think it's doing it while cutting, I would check my ground and look at my consumables, then check mach 3 and make sure your up and down lights are working with the torch height and volts. I have a three year old 5 by 10 ez plasma table and have been very happy with it and the service. Hope some of this helps. LATER,,,,,,,,CURLY
