How do I slow down the solid part rendering ?
Results 1 to 3 of 3
Thread: How do I slow down the solid part rendering ?
    Dec 2004
    Default How do I slow down the solid part rendering ?
    when I render the part it draws it super fast on the screen and I want to slow it down,, there has to be a setting for it but I can`t find it
    May 2006
    Default Re: How do I slow down the solid part rendering ?
    EZ-CAM's simulation can be controlled under the stock setup using the slider, or you can use 0 thru 9 on your keyboard. 9 would be the fastest speed and 0 steps through using the enter key.
    Sep 2007
    the netherlands
    but sometimes 7 is to slow and 8 to fast .
    the steps could be better spaced.
    greetings bertus
