Results 1 to 5 of 5
Thread: Forward these links for reference only!
    Nov 2009
    China
    We join in this thread to Give Suggestion and Help to other machine user here>
    Need Help!- CO2 laser cutting white acrylic- burns
    http://www.cnczone.com/forums/laser_..._acrylic-.html
    Regards/Mike
    Nov 2009
    China
    Just IN- DXFTool for CorelDRAW Standard Edition
    Nov 2009
    China
    GWEIKE Power Supply PLEASE HELP
    We join in this thread to Give Suggestion and Help to other machine user.
    GWEIKE Power Supply PLEASE HELP http://www.cnczone.com/forums/laser_...ease_help.html
    Jun 2008
    morocco
    Question cutting problem
    Problem of laser power which is not the same on the whole table, it can cut with the same power till the center of the table but when going far to the extreme right of the table at the top or at the bottom it can not cut i have checked the table it is weel leveled .
    what do you suggest ?
    the table is 900mm*600mm and the laser tube is Reci 80w used for only 2 hours.
    Nov 2009
    China
    Yes ,you are right . The table is not on the same level that you need to adjusting the table untile each conner and the center are on the same leave .
    Mary from XYZ Machinery
    info@xyz-tech.com
    1. Need Help!- CO2 laser cutting white acrylic- burns
      By VBLietuva in forum General Laser Engraving & Cutting Machine Discussion
      Last Post: 01-26-2012, 08:18 AM
    2. Replies: 0
      Last Post: 08-14-2011, 10:08 PM
    3. Laser Cutting 3/8" White Acrylic & Getting Burned Edges
      By RJlaser in forum General Laser Engraving & Cutting Machine Discussion
      Last Post: 04-06-2010, 11:52 AM
    4. Newbie- Hi and help needed cutting white acrylic!
      By craig3000 in forum General Laser Engraving & Cutting Machine Discussion
      Last Post: 02-28-2010, 08:28 PM
    5. laser cutting acrylic - art application
      By charper in forum General Laser Engraving & Cutting Machine Discussion
      Last Post: 11-07-2006, 01:50 AM
