Go Back   CNCzone.com-The Largest Machinist Community on the net! > WoodWorking Machines > Commercial CNC Wood Routers > Excitech routers
Excitech routers Discuss excitech routers here.
Old 10-26-2009, 02:58 PM
cenicero is on a distinguished road
Help! I deleted the firmware from my DSP controller
Hi all,
I bought a Chinese CNC router wich I received a few days ago, itīs not an Excitech router, but as far as Iīve seen itīs identical. It came with a DSP controller, and the "UsbCam" driver and the Signtek program to be installed on a PC.
I installed the driver and then the program, but when I opened the program I found all the menus and options were in Chinese! I connected the DSP to the PC, and the red LED started flashing (which means the DSP was recognized by the program). Then I only had to find the way to change the program from Chinese to English, so I blindly clicked all the options. At some point, a progress bar appeared. I donīt know what i did but, after that, my DSP stopped working at all... Oh my good, I think I deleted the DSP firmware!
Now if I turn on the DSP, I canīt see the logo and the "Go to home?" question anymore. The screen and the red LED light up, but no matter what I do the screen is always blank (no text, no logo, nothing).
I asked about this to my vendor and they told me I could reset the DSP memory by pressing the OK button and switching on, but it didnīt work. Iīm not sure if they will be able to give me a fast solution, and of course I donīt want to ship the DSP to China for repair because Iīm eager to start using the router as soon as possible.
My guess is: if I was able to delete or overwrite the DSP memory from the Signtek program, I should also be able to restore it to its original settings. Am I wrong?
I know many of you have a DSP controller which is identical to mine. Do you have any suggestion to solve my problem?
Could anyone send me the English version of the Signtek program?
I know there is an English version because Shannon posted an screenshot here:
RemainCNC NZ Excitech 1530 router.
But I canīt find the program to download anywhere.
Any help would be much appreciated, thanks!
Old 10-26-2009, 04:46 PM
Andre09 is on a distinguished road
Recovering the DSP Handle
Hi Cenicero, the only option for you is to send it back.
I am in the same boat, I tried to the update function using the SIGNTEK software. The same thing happened to me. For me, initially the screen got stuck on this line: "it is bootloading... please wait". From there on, if I tried updating anything else, SIGNTEK would tell me that that it could not update because the controller was running.
Then the manufacturer suggested I could press the "OK" button before plugging the DSP Handle into the computer and this would give me the option to reset the program. This got me to the Emergency screen,where I could format the drive, but it had no effect on repairing the firmware.
I was then informed that there are two editions for the DSP. If you started the DSP originally and it had "CNC ROUTER" as the initial logo, then this one needs to be sent back to China for repair, there is no way to do it through the SIGNTEK software.
Let this be a warning to anyone with the DSP controller. Don't mess with it, you will regret it if you do. I don't know why they have designed the DSP to make it so simple to stuff up the Firmware, but there you go..
Name:	it is bootloading... please wait.jpg‎
ID:	91999   Click image for larger version
Name:	Update Programe(P) - Cannot Update.jpg‎
Old 10-26-2009, 05:47 PM
My DSP didnīt have "CNC ROUTER" as the initial logo, it showed the logo from my vendor instead, and then the text "Go to home?".
Does this means my DSP could be restored throught the Signtek program?
I sent you a PM.
Old 10-26-2009, 05:56 PM
Big S is on a distinguished road
The DSP program can be reinstalled using the signtek software, (been there done that) you also need the software file( it should be something like 'Setup(RZTH501)_E_200721'
Cenicero, can you pm me your email address and I will send you the English version of the host program. Its 6MB+
Thanks,
Shannon.
Excitech 1530 Router owner,
WWW.REMAIN.CO.NZ.
Old 10-26-2009, 06:13 PM
Is that an executable file? Like 'Setup(RZTH501)_E_200721.exe'?
I have the following files:
0501_1.0_Menu C.txt (1.91KB)
0501_1.0_Menu E.txt (2.07KB)
RZNC-D5416-1.2(zhb36)_init.NEWBIN2 (63.2KB)
RZNC-D5416-1.2(zhb981)_normal.NEWBIN2 (172KB)
zhbLabel501_C_v17.label (24.4KB)
zhbLabel501_E_v17.label (29.0KB)
Maybe the file that you are talking about is one of those '.NEWBIN2'? Which one of them?
I sent you a PM with my email address.
Old 10-26-2009, 06:18 PM
Hi that is correct, The newbin file is the one you want, If you could email me the RZNC-D5416-1.2(zhb981)_normal.NEWBIN2 (172KB) file that would rock, My latest version is only zhb 662.
I have emailed you the signtek host program.
Thanks,
Shannon.
WWW.REMAIN.CO.NZ.
Old 10-26-2009, 06:30 PM
Hi Shannon, did you have a blank screen when yours went bad, along with the message that the "controller is running, cannot update it" on SIGNTEK ? I do not have the file "Setup(RZTH501)_E_200721", are you saying thats all I need to get it going again ?
I was told specifically that I would need to send it back ??
Old 10-26-2009, 06:40 PM
I didn't have my DSP go bad, I was playing with the software update feature.
I think one of the versions of the signtek had that message when trying to update the DSP. It's a while ago now and I can't quite remember exactly.
I think that file I posted above is one of the signtek versions. I have emailed cenicero one of the software versions. Hopefully it is the right one as i am not sure what one worked.
Pm me your email and I can send you the files.
Shannon.
WWW.REMAIN.CO.NZ.
Old 10-26-2009, 07:13 PM
Shannon, I already installed the English version of the program that you sent me but I canīt still find the way to restore the DSP firmware.
If I go to the 'Update Programe' option below the 'Update' menu, it asks for a .newbin2 file.
If I select the file 'RZNC-D5416-1.2(zhb981)_normal.NEWBIN2', I get this error: 'The selected file is not valid update file!'.
But if I select the file 'RZNC-D5416-1.2(zhb36)_init.NEWBIN2' I get no error and a window titled 'BIN file information' pops up with these data:
-Auoter: zhb
-Version: 2.1
-SN: 36
-Hardware: RZNC-D5416/3/
-Program type: Initial program
-Description:
...and two buttons: YES NO
I click on YES and then it says "initial program updated!"
But I see no difference on the DSP.
Iīve also found two options below the 'Operations' menu which look interesting:
'Backup Configure Data' and 'Restore Configure Data'.
If I click 'Restore Configure Data', it asks for a .dat file. But obviously I donīt have this file. Is this the option I have to use to restore the DSP firmware?
In that case, how can I get the .dat file I need?
Old 10-26-2009, 07:24 PM
I think the .dat file is one that you can save from your DSP, It saves all the step pulse settings and user changeable DSP settings. It doesn't save the inbuilt software. (I think )
The initial program seems to be a basic operating system that the DSP reverts to when it is booting up. The main program it seems to use it the one that oyu cant get to load (as yet)
I have sent you version 1.3 of the signtek software, hopefully that one works.
I will check both of them on my DSP when at my workshop today.
Shannon.
WWW.REMAIN.CO.NZ.
  #11   Ban this user!
Old 10-26-2009, 08:04 PM
I installed the version 1.3. I used the 'Update Program' option, selected the 'RZNC-D5416-1.2(zhb981)_normal.NEWBIN2' file and the message 'Normal program updated!' appeared, but again this had no effect at all on the DSP.
I have an idea: could you use the 'Backup Configure data' (below the 'Operations' menu) on your PC?
It seems that option will create a backup of the information stored in the DSP (probably including the firmware?). When you generate the backup file (.dat), please send it to me. Then Iīll try to restore my DSP using your backup file. I donīt know if it will work, but I canīt think any other solution.
Probably youīre right, but my only hope is that youīre wrong
Otherwise I think Iīll have to send my DSP for repair...
  #12   Ban this user!
Old 10-27-2009, 03:11 AM
No Luck With Any Other Versions of Software
I have surrendered to that the fact that the DSP has to go back to China now for sure. Nothing works.
This is a quote from the Manufacturer:
What I ask is if when the DSP is well, it has the logo of "CNC ROUTER" or not. As we have two editions for such DSP. the technician told if it has the logo, you have to send the DSP back and we recover it for you. because this one if you update the wrong file inside, you can not re-update it back to lower edition.
So this leads me to think that either Shannon did not delete his firmware as it seems that both Cenicero & I have, or that he has a slightly different version of the DSP Handle which responds better when things like this happen. Either way, it wont work if It doesn't get sent back, so off it goes...
Im grateful to have support from my supplier, given the recent posts from others on this forum.
Big Thanks to Shannon who assisted both & Cenicero in our attempts..
New PICStep firmware available Garfield2 PicStep Controllers 19 12-07-2010 12:07 AM
VSD-A firmware upgrade Xerxes Granite Devices 4 10-27-2008 04:18 PM
Hi Firmware V1.1 20MHz elogicca PicStep Controllers 0 10-01-2006 06:46 PM
PICStep Firmware V1.01 santiniuk PicStep Controllers 7 08-18-2005 08:23 PM
DMC-1700 firmware Karl_T CamSoft Products 0 07-31-2005 03:24 PM
