Go Back   CNCzone.com-The Largest Machinist Community on the net! > WoodWorking Machines > Commercial CNC Wood Routers > Excitech routers
Excitech routers Discuss excitech routers here.
Old 09-12-2009, 07:02 PM
xjdubber is on a distinguished road
dsp problems shg609
Having issues with my dsp controller, if i want to set z0 as soon as the tool hits the 0 block it locks up. if i set it by hand it locks up, if i go trough a few menu's it lock up. anyone have this problem?
Old 09-13-2009, 12:09 AM
Smile Well never mind......
figured it out. could not find my unislan memory stick so i was using a diffrent one (2gig) found that when i formatted it for fat32 instead of fat16 and after doing the inner format in the controller it worked fine. this might be of help to you of those who were having problems with diffrent memory sticks.
More DNC problems jnc Haas Mills 22 05-27-2009 07:16 PM
New Machine Build- PIC Problems niwatori1 General CNC (Mill and Lathe) Control Software (NC) 1 10-05-2008 02:57 PM
TM-1P problems tmt_92021 Haas Mills 1 10-17-2006 02:22 PM
'z' problems bo whipkey Mach Software (ArtSoft software) 8 10-10-2006 09:06 PM
More problems Cold Fusion Gecko Drives 8 09-09-2005 02:19 AM
