| Excitech routers Discuss excitech routers here. |
| Spindle speed command from G-code Hello, I have recently purchased an Excitech router, with DSP and HSD spindle. I came to an issue where i cannot command the spindle driver with the speed of spindle in Gcode. It only runs at maximum (300Hz/18k RPM). Does the DSP handle puts only on/off signal to the driver? How are you working with different speeds? Thank you for your help, ddanutz1 |
| You can change Spindle speed through the inverter keypad. Scroll down to the " How to operate the Excitech " thread. There is plenty of info about it there. Rocket |
| almost solved Hi Rocket, Thank you for your reply, i have spent half a day searching for information on this item. Fortunately i have somehow solved the problem: the DSP works with 6 speeds preset(it can be changed in the menu) and each speed number is related to some binary 3digit number which can also be configured in the menu. For speed S1 i get 50Hz (3000RPM), for S6 i have 300Hz(18000RPM), this is good enough for me. It requires however changing the tool database in CAM. thanks, ddanutz1 |
| whole G-Code REPEAT command ?? | LockTech | G-Code Programing | 14 | 08-08-2010 11:21 AM |
| Spindle speed varies from the command to the actual | diemech | Haas Mills | 4 | 08-11-2009 05:31 AM |
| G code F speed | japco43 | G-Code Programing | 2 | 03-11-2009 07:49 AM |
| Newbie- Set & Max Spindle speed code ? | Jami9104 | Fanuc | 2 | 06-13-2008 06:37 AM |
| BPSeriesI / Centroid control- Spindle speed all out of whack with speed dial? | peter.blais | Bridgeport and Hardinge Mills | 9 | 08-08-2006 04:29 AM |
