| Excitech routers Discuss excitech routers here. |
| Hi Guys, I need some help. I am using Vectric cut 3D to create the g code and output is G Code mm (*.tap). I then insert the USB drive into the DSP and run the file, it goes through it check file and for some reasons it has be stopping at 86% on one file then I tried another file and it went to 98.86%. When I actually ran the 86% file it only cut 86% so I am a little confused. Should it check to 100% if so why isn't it? |
| open the code in notepad and insure it saved all of the data!! i have pulled the stick after loading a vectric file and found it did not finish loading jim
__________________ James McGrew camaster x3, aspire software www.mcgrewwoodwork.com |
| How do I insure that all the code is their, Im happy to post it for you to look at if you can. |
| it should want to return to xy0 at the end of the file jim G1 X44.0337 Y2.7523 G1 X44.0273 Y2.7515 G1 X44.0210 Y2.7509 G1 X44.0148 Y2.7504 G1 X44.0087 Y2.7502 G1 X44.0028 Y2.7500 G1 X43.9970 Y2.7500 G1 X2.9970 Y3.2500 G0 Z0.2362 G0 Z0.7874 G0 X0.0000 Y0.0000
| This is the last part of the code, what is M30? Y697.641 X400.000 Y698.061 X0.000 Y698.481 X400.000 Y698.901 X0.000 Y699.321 X400.000 Y699.741 X0.000 G0Z5.000 G0Z5.000 G0X0.000Y0.000 M30 |
| Simon, Ramon is at work tomorrow ( Friday ). If you can find the time - come and see us. Maybe bring your USB stick and also the DSP Controller We can download some crv files from the vectric website, load them onto your USB stick and try them out on our machine. If that goes OK we could then plug in your DSP Controller and try the same thing. Our 3 new machines should arrive next week sometime - so i do not mind playing around with our current machine now in order to try to sort out your problem. Our DSP cable is a bit dicky ( Jerry is supposed to be sending a replacement..... Well that was a month ago! ), but we should be able to make it work. Look forward to seeing you if you can make it. Rocket. |
| Jim, Your links continue to teach and inform us. Good on ya mate! Rocket. |
| Thanks for your help James, and i'm a big fan of your work. Rod, I will bring my bits down tomorrow and see how we go. Thank goodness you are nearby. See ya tomorrow. |
#10
| just try'in to keep the old brain functioning!! jim
#11
| Just a quick update, I took my file and DSP to to Rockets place today to test out. 1. We tested my file on Rockets machine and have a guess what happen - It worked perfectly. 2. We then connected my DSP to Rockets machine and tested the same file and yep, it worked perfectly. 3. Now that I started to look like a numpty I decided to take my bits home and test it out again on my CNC. 4. Got home connected the DSP and loaded the file and it worked perfectly again. So now I am a real numpty. OH by the way Rocket, thankyou for letting Ramon help me out today. I now have a bit more confidence to push forward and start cutting my molds. Thanks guys. |
#12
| Simon, That is excellent news. So it was just one of those inexplicable glitches. Only one thing to do now Crank it up! |
