Go Back   CNCzone.com-The Largest Machinist Community on the net! > WoodWorking Machines > Commercial CNC Wood Routers > Excitech routers
Excitech routers Discuss excitech routers here.
Old 05-18-2009, 12:23 AM
Cabinet Man is on a distinguished road
Operating the SHMS1325C on 60Hz power
I am located in Toronto, Canada. 600V 3-phase 60Hz.
I am considering the purchase of an SHMS1325C with 3.5Kw HSD toolchanger and servos, Syntec controller, Becker vacuum pump, directly from Jerry Zhang, Excitech, Jinan, China.
Is there anyone in Canada or the USA who owns one and operates it on 60Hz power? What are the possible complications?
Jerry says they commomly confugure these for 220V 3-phase, so a transfomer should do the trick.
Anyone using the Syntec controller? I like the features of being able to edit code in the controller and connect to computer with USB. Comments??
cheers all,
CABINET MAN
Old 05-18-2009, 11:20 PM
yanjue is on a distinguished road
I hope you don't think to make production with a 3.5kW spindle.
Normaly electronic can support 50 and 60 Hz. The main problem is with motor. At 60 Hz, motor run faster and the current drawn by the motor is lower. Lower current = less power. Higher speed on vacuum pump = more power requirement. The motor have a very short life.
Before buying in China, i suggest to you, to considere other cnc builder like AXYZ (cheap), KOMO (top quality/speed) or other company with support in Canada.
Yan
Old 05-20-2009, 07:44 AM
Big S is on a distinguished road
FWIW, I think most if not all of the components are able to run on 60Hz. Best to check with Taney (he's Da Man) to find out for sure. The spindle runs off an inverter so the 60Hz won't change the speed it runs at.
Shannon.
Excitech 1530 Router owner,
WWW.REMAIN.CO.NZ.
Old 09-15-2009, 05:07 AM
slick66 is on a distinguished road
Hi All
I got my Excitech 1325 cnc about a month ago. It worked for a day then the dsp broke , this has been replaced but now the spindle turns for about 2 secs and i get an error message oL, I've reset the settings to factory default settings but this hasn't helped. I've got a 6kw spindle, can someone please give me advice as the local agency won't help me because I ordered the machine directly from China.
Are Ajaxcnc still operating DaveinUK Bridgeport and Hardinge Mills 3 03-06-2009 05:25 AM
Which operating system..... T63-A-700 Mach Software (ArtSoft software) 8 12-24-2008 04:26 PM
Operating Sys. wantsout Vectric 16 10-20-2008 06:39 PM
Got a 60hz chiller instead 50hz need help wickedboysap Laser Engraving & Cutting Machines 2 04-18-2008 01:28 AM
Operating Voltage jhwatts Hobbycnc (Products) 6 10-13-2005 12:29 PM
