Page 4 of 4 FirstFirst 1234
Results 37 to 47 of 47
Thread: usb problem excitech
  1. #37
    Registered bananafish's Avatar
    Aug 2008
    thanks woodcam
    The problem is I have no control of the machine since I have used incompatible USB.
    With my original USB stick DSP can read the program but doesn't do the job correctly.
    G-code cannot control spindle rev, XYZ working speed or distance.
    Does incompatible USB actually corrupt DSP configuration?
    How did you restore your DSP.
    Do I need to reconfigure using DSP?
    Or need to format and reinstall DSP?
  2. #38
    Feb 2004
    Beacon, NY
    Restoring DSP System Settings
    Bananafish,
    There are two memory segments resident on the DSP, the DSP program and the DSP system settings. An incompatible USB seems to effect the system settings - and if you have not saved those settings (there is a way to transfer them to the USB and than to a host PC as a backup but I have never made the attempt and the procedure is not to clearly documented) so the only way to restore the system settings is to manually go through the system menu options and enter the correct parameters.
    The Excitech DSP manual documents most of the settings.
  3. #39
    Jan 2006
    New Zealand
    I haven't had any issues with incompatible USB sticks messing up the system settings in my DSP. The only thing that happened for me is that the DSP can't read the files on the USB stick.
    I have however used the PC host program to backup my settings. If you are doing this you need to use a laptop that is disconnected from the power (running on batteries) or disconnect the DSP from the machine so that it is powered from the USB port on the computer. Failure to use one of these methods usually creates a short through the DSP letting out the magic smoke. (very hard to reinstall magic smoke)
    The host program works well, I have used it to save and restore the system settings. There is a backup settings in the drop down menus and it saves a file to your computer hard drive. You select the same file when you update the system settings.
    Shannon.
    Excitech 1530 Router owner,
    WWW.REMAIN.CO.NZ.
  4. #40
    Aug 2008
    Big S,Woodcam
    Thank you for your kind reply.
    I have actually tried to read the file from USB memory which has loads of other files in it. That could have caused the problem.
    I will try to restore the settings manually and will make a report later on.
    Thanks again
  • #41
    Registered Inuk's Avatar
    Feb 2010
    Quote Originally Posted by woodcam View Post
    Bannafish
    The spindle speed control is set in a register in the system setup menu.
    Follow the instructions I received from Jerry Zhang quoted below.
    MENU--MACHINE SETUP--SPINDLE SETUP--INPUT SPINDLE ST 7E NUMBER--LINES STATE WHEN SPINDLE IS OFF DOWN DOWN DOWN DOWN--OK--UP UP DOWN DOWN--UP DOWN UP DOWN--UP UP UP DOWN --UP DOWN DOWN UP--UP UP DOWN UP--UP DOWN UP UP .
    Hi Woodcam, I've never been able to control speed with code and have always had to set it via the VFD. Do these setting enable Speed Control from code ???
    Settings for Spindle Set Up on mine are:
    INPUT SPINDLE ST 2e NUMBER:
    LINES STATE WHEN SPINDLE IS OFF: DOWN DOWN DOWN DOWN
    LINES STATE WHEN OF 1st GRADE SPEED:UP DOWN DOWN DOWN
    I notice you appear to have more settings. I only have the two lines. What does the UP DOWN refer to, any idea ?
    Cheers
  • #42
    Feb 2004
    Beacon, NY
    DSP Speed Settings
    Quote Originally Posted by Inuk View Post
    etc. etc.....
    Banafish,
    Sounds like you have a different DSP - I have the table top SHG0609 purchased in the second half of 2009.
    The SHG0609 DSP software provides a choice from six possible speed settings which require six corresponding binary register values (three bits binary for each setting).
    I thought you had a SHG0609????
  • #43
    Aug 2008
    Woodcam
    I have SHG1212 late 2009 model.
    My spindle set up is same as Inuk's.
    With those setting above I can't control the spindle via program or DSP.
    According to DSP user manual we should be able to change spindle speed while running a program by pressing the key (z+ 3)and (z- 7)
    I have tried without success.
    What else I can do to make it work? any idea???
  • #44
    Feb 2004
    Beacon, NY
    DSP Spindle Speed Settings
    Quote Originally Posted by bananafish View Post
    Woodcam
    Sounds like another setting is required or the bit setting UP DOWN sequence is incorrect.
    I have no idea as your DSP software is not the same as mine as it has two settings for speed, mine requires six and incrementing or decrementing the speed is implemented by pressing the Z+ or Z- keys respectively alone which cycles through the six speed settings.
    Perhaps you can find a 1212 owner who is running without a problem and compare settings.
    Any luck with Excitech support?????
  • #45
    Aug 2008
    Smile
    Problem solved !
    I had a reply from Excitech.(It was very quick indeed !)
    Machine is now working perfectly.(I think )
    The settings I needed to change were
    INPUT SPINDLE ST 2e NUMBER: to INPUT SPINDLE ST 7e NUMBER:
    Then 7 lines of setting came up. ( I only had 2 lines before )
    The setting I have is
    0 down down down down
    1 up up down down
    2 up down up down
    3 up up up down
    4 up down down up
    5 up up down up
    6 up down up up
    Now spindle speed can be controlled via DSP and program(v-carvpro).
    >>> Inuk
    I thins your DSP is same as mine.
    Try those setting above.
  • #46
    Feb 2010
    Sounds like we're getting somewhere. I'll check this out next time I fire up the machine.
  • #47
    Feb 2010
    Changing the Spindle settings to 7e didn't have any effect other than give me 5 speed choices on screen, non of which altered the spindle speed.
  • Page 4 of 4 FirstFirst 1234
    1. Excitech SHM 1530A
      By GraHutch in forum Commercial CNC Wood Routers
      Last Post: 03-18-2012, 10:39 AM
    2. Excitech Z-zero mod.
      By Big S in forum Excitech routers
      Last Post: 03-04-2010, 08:08 PM
    3. Excitech Parts
      By bradbergemann in forum Excitech routers
      Last Post: 06-22-2009, 05:33 AM
    4. Excitech new changes for CNC router
      By dianafeng in forum Excitech routers
      Last Post: 12-01-2008, 08:14 PM
    5. The sh-cnc Excitech 1530 B
      By rocket67 in forum Excitech routers
      Last Post: 08-13-2008, 01:53 PM
