Go Back   CNCzone.com-The Largest Machinist Community on the net! > WoodWorking Machines > Commercial CNC Wood Routers > Excitech routers
Excitech routers Discuss excitech routers here.
Old 04-13-2009, 09:19 PM
Big S is on a distinguished road
Excitech Z-zero mod.
Hi all,
Here is a quick post about how I got my Z-zero sensor to work. When I had the original brass puck, it would only contact intermittently. I think this is partially due to the ceramic bearings in one end of the spindle not helping the electrical circuit much. I hadn't actually tried to use the sensor due to others on here breaking tools when theirs fail to sense properly. I took heed of this and tested mine by touching the sensor in the spindle nose manually as the z-axis was descending. The sensor would work every time if touched on the spindle casing but only intermittently when touched on the parts that spin.
What I have done is use the wire that normally connects the the brass puck and used it with a micro switch to connect the wire to ground. The round black thing is the inside of an old computer fan and it has a micro switch inside. The center of the fan motor is removed but the shaft still slides vertically in the original bearings. The flex wire that was supplied with my brass puck is multistrand, so I split the connections and used that for the earthing wire as well as the sensor wire. The earth can be connected anywhere on the structure inside the Z-axis housing.
As you can see from the photos I have made mine with a plug on it, I would NOT recommend this, or if you do, make sure that the socket connections close when the plug isn't inserted. I haven't broken any tools because of it but it has run down too far without stopping because of the plug not being correctly inserted. I just happened to notice this in time and stopped the machine.
I intend to make a new Z-zero sensor at some stage. I will make the following changes.
1, A heavier base so the sensor sits flat on the material without having to physically hold it down.
2, Make the sensor out of metal and not plastic to stop the errors from the flex in the plastic when the tool doesn't push dead center.
3, I will hard wire the sensor into the machine and not use a plug.
4, I am also considering a backup switch inside the sensor for if the micro switch fails (as they all do eventually).
I have also included a basic circuit diagram (done in MS paint )
Shannon
ID:	79682   Click image for larger version
ID:	79683   Click image for larger version
ID:	79684   Click image for larger version
Excitech 1530 Router owner,
WWW.REMAIN.CO.NZ.
Old 04-13-2009, 10:12 PM
bradbergemann is on a distinguished road
Thanks for the up Shannon!
Where does the existing wire go? mine didn't come with one and I would like to add it.
Old 04-13-2009, 10:30 PM
Hi Brad,
The connection is on the DSP breakout board inside the control box, I am not sure what machine you have but I suspect most of the breakout boards are similar.
The photo shows where the DSP breakout board. I think you will be best to check there first. The DSP pdf is too large to upload here so I have emailed it to you.
I am heading over to my workshop very soon, I will check exactly which connections are used on my machine.
Shannon.
WWW.REMAIN.CO.NZ.
Old 04-15-2009, 07:32 AM
cabnet636 is on a distinguished road
does this help
here is how our z zero, as we call them "touchplates" are. they are connected with a connector like shannons we get from radio shack and are connected with amplifier cord. in one photo you can see the cord connection at the breakout box.
jim
ID:	79744   Click image for larger version
ID:	79745   Click image for larger version
James McGrew camaster x3, aspire software
www.mcgrewwoodwork.com
Old 04-22-2009, 05:38 AM
woodworker73 is on a distinguished road
Some one could help me how to use the zero tool?
Taney reply:
First count the thickness of the brass block, input the thickness value of the tool sensor into the DSP handle: MENU--MACHINE SETUP--C.A.D Thickness.
Then press MENU+ON/OFF togehter and relase the two buttons at the same time, the spindle will go down, when the tool tip touch the sensor the spindle will go up, and the system will remember the Z-0 point
Old 05-23-2009, 12:34 AM
Shannon,
Here's a photo of my bb. any suggestions before i try some wiring? you know what they say, "can't put the magic smoke back in the box once its out".
[IMG][/IMG]
Old 05-23-2009, 04:32 AM
My guess is the connector on the bottom left.
Shannon.
WWW.REMAIN.CO.NZ.
Old 03-04-2010, 08:08 PM
Inuk's Avatar
Inuk is on a distinguished road
Zero plate
Hi, I have a SHG1212 that did not come with a Z Zero device but would like t use one. Is it basically a plate connected to the frame ground,... or on the breakout board ? Which ? If the breakout which connection ? I can get the adjustment to initiate but not stop.
Cheers
Excitech SHM 1530A GraHutch Commercial CNC Wood Routers 3 02-20-2011 07:11 AM
Excitech Parts bradbergemann Excitech routers 7 06-22-2009 05:33 AM
Excitech Routing Software Web.eng Excitech routers 2 12-09-2008 06:22 AM
Excitech new changes for CNC router dianafeng Excitech routers 0 12-01-2008 08:14 PM
The sh-cnc Excitech 1530 B rocket67 Excitech routers 7 08-13-2008 01:53 PM
