Go Back   CNCzone.com-The Largest Machinist Community on the net! > WoodWorking Machines > Commercial CNC Wood Routers > Excitech routers
Excitech routers Discuss excitech routers here.
Old 04-02-2009, 11:11 AM
bradbergemann is on a distinguished road
Excitech Parts
Thought I would start a parts thread.
I'm having problems with my on/off power switch. Never really worked right, probably damaged in shipping a little. Now, its just annoying. Anything special I should consider before replacing it?
Old 04-05-2009, 01:25 AM
jubee is on a distinguished road
Check ALL of your wiring.(earthing issue)???
I had the same problems from the start.
Very poorly put togeather!!!!!!
Regards
Jubee.
Old 05-11-2009, 09:06 PM
Does anyone have a complete wiring schematic?
Old 05-12-2009, 08:24 PM
cabnet636 is on a distinguished road
which machine do you have?
replacing the on/off switch is not to difficult
jim
James McGrew camaster x3, aspire software
www.mcgrewwoodwork.com
Old 05-13-2009, 11:09 AM
i have the xhym1325. i know this sounds simple, but i'm prone to making things more complicated than necessary most of the time. my on/off button functions this way; one push and the button goes all the way in, and releases half way back out. at this point, the router powers up. a second push, and the router powers down. a few weeks ago this changed. now, after the first push, the button releases half way, but the power does not stay on. it does stay on if i hold the button in, but it won't stay powered up by itself. my first thought was that the button is broken or the contacts are worn down. so, i took it all apart and can't find anything wrong. no broken plastic parts or worn down components. i did discover that both of the n.o. contacts blocks have a sight window in them so you can see the contacts. they do not look burnt or damaged.
here's my questions. when the button is pressed the first time, and contact is made are the contacts in the switch supposed to stay in contact, or are the supposed to separate? mine now have a gap in between them. is this a momentary or a latching switch? is the main contact that this switch powers supposed to stay latched regardless of the switch?
Old 05-13-2009, 11:57 AM
sounds like a magnetic switch any chance of a photo,
jim
Old 05-23-2009, 12:25 AM
Jim,
Finally got a photo uploaded. take a peek:
[IMG][/IMG]
Old 06-22-2009, 05:33 AM
Farproducts is on a distinguished road
Talking about parts...do you guys work with the vacuum bed? MY machine (3000 x 2000) is less than a year old and the levers at the ball valves are all worn out...used a vice grip, now they are nice and buggered....
Anyone else have the same problem?
Excitech SHM 1530A GraHutch Commercial CNC Wood Routers 3 02-20-2011 07:11 AM
Excitech new changes for CNC router dianafeng Excitech routers 0 12-01-2008 08:14 PM
The sh-cnc Excitech 1530 B rocket67 Excitech routers 7 08-13-2008 01:53 PM
Excitech controller quest Matty Zee Commercial CNC Wood Routers 16 08-07-2008 05:26 AM
