Go Back   CNCzone.com-The Largest Machinist Community on the net! > WoodWorking Machines > Commercial CNC Wood Routers > Excitech routers
Excitech routers Discuss excitech routers here.
Old 03-27-2009, 06:45 AM
Farproducts is on a distinguished road
Cutting of G11 Glass filled phoenolic
Hello everyone,
I have quite a big job on cutting G11 glass filled phoenolic. I'm looking for advice on cutting this material. Speeds, rpm's etc.
Thank you!
Conrad
Old 03-31-2009, 01:22 AM
Big S is on a distinguished road
I would suggest you use solid carbide tooling designed for use on composites.
I would also get the feed rate as fast as you can while maintaining the finish required to make the cutter last longer. You may have to slow down the spindle rpm and lower the feed slightly to stop the tooling overheating.
FWIW
Shannon.
Excitech 1530 Router owner,
WWW.REMAIN.CO.NZ.
Old 04-01-2009, 07:43 AM
Hi Shannon, We are using the Belin Diamond tipped end mill. I've slowed the rpm's and feed rate down and increased the amount of passes. It cuts it very nicely, but the glass in the material is very abrasive, so the bits don't last that long. At least the customer is paying for it :-) Thank you for the advice.
glass filled nylon Ryno Glass, Plastic and Stone 5 02-16-2010 02:01 PM
Newbie- Cutting Art Glass jayglass Glass, Plastic and Stone 7 09-12-2008 05:50 PM
Machining glass filled nylon ronmor Glass, Plastic and Stone 1 02-08-2008 10:07 AM
Need Help Cutting Glass!!! ariel 1 Glass, Plastic and Stone 19 07-10-2007 02:53 AM
Glass cutting gabi68 DIY-CNC Router Table Machines 7 11-11-2006 09:34 PM
