Go Back   CNCzone.com-The Largest Machinist Community on the net! > WoodWorking Machines > Commercial CNC Wood Routers > Excitech routers
Excitech routers Discuss excitech routers here.
Old 02-26-2009, 10:12 AM
woodworker73 is on a distinguished road
SHM0609 [Official thread]
I'm waiting my "little baby" coming home so I think may be a good idea start an Official thread on this machine.
Some guys on this forum bought it and could help newbie like me or others who want to buy.
If not useful delete the post
Official SHM0609 english home page:
http://www.webshcnc.com/english/6096m.asp
Official Excitech picture:
charnwooduk router unboxing post (pictures attached):
http://www.cnczone.com/forums/showpo...postcount=2279
First question:
  • what type of maintenance to do when router arrive.
ID:	76521   Click image for larger version
ID:	76522   Click image for larger version
ID:	76523   Click image for larger version
Old 03-01-2009, 11:56 AM
6bx 6bx is offline
6bx is on a distinguished road
Dear friend ,
I have bought from China 3 weeks ago an XYZ 6090 and i am in big trouble still.By the look of the pictures of your baby it MAKE a big difference compare to mine.Can you please advise if it came with NC studio program?Did you have any problem with it?
Looking forward for your reply.
Regards
George
PS:regarding your question of maintenance of the CNC,the most and above all rules from all is clean rails,and sharp tools.
Old 03-02-2009, 06:36 AM
Hi.
First i don't know what's the Ncstudio, but if I correctly understand:
The SHM0609 router is provided by the DSP controller that accept the Gcode.
I found on the forum some posts concerning the NCstudio, hope it help:
problems Chinise Router NcStudio
http://cnczone.com/forums/showpost.p...00&postcount=1
the search query:
http://cnczone.com/forums/search.php?searchid=3423784
Could you post the home page factory of your machine?
Thanks for suggestions.
Old 03-03-2009, 05:58 AM
6bx 6bx is offline
Dear friend
thanks for the reply,and the company who sell the router is XYZ-TECH_CNC_Equipment_Co_Ltd.
You see i have bought from the States a new card so i can work with Mach3 instead of the NCstudio wich the router came with.After some reading and searching i came to a STOP with the instalation because the router it has a Hight Frequency inverter to control speed on the motor( DZB brand 200model).
The reason i have ask you for more information is to advise if you can and obviously if possible for you,to send me a photo of your installation regarding the four wires coming out of the bottom of the inverter .In the standard small break out board(BOB)which came with it goes on a fuse with the following order G(red),1,2,3.
What program yours came with?
Is it able to work with Mach or?
Regards
George
Old 03-03-2009, 06:13 AM
George, my router is on the way (I'm waiting it within 3 weeks) so unfortunately I can't help you.
You can try to send a PM to charnwooduk, a forum member, he got the router 3 weeks ago and may help you.
Take care
Ciao
Old 03-05-2009, 08:22 AM
charnwooduk is on a distinguished road
Originally Posted by 6bx View Post
Dear friend
I suspect that this is a different company to Excitech.
I found this picture of the "XYZ-tech" 0609 and it looks like a different machine to the one excitech produce - http://www.ttnet.net/show_html.jsp/c...no/000/type1/A
I am using the DSP to control the machine so cannot advise on how to set-up with mach 3
Old 03-05-2009, 08:41 AM
Yeah, it's not the same router.
Also specifications are different.
Charnwooduk, tell me your impressions after 3 weeks of SHM0609 use.
What type of maintenace you did when you got the router at home?
Ciao
Old 03-05-2009, 12:55 PM
For maintainance, i simply removed the dust covers for the rails, wiped everything clean and applied lots of grease to the lead&ball screws and wiped oil over the rails.
Also the machine bed was not quite flat, but as it is a hard plastic "foam", it is easy to mill flat (you can see the pattern left in my pictures.. bed is now perfectly flat.
I also adjusted the position of the spindle as it was mounted too low. The new position gives the full 120mm of travel (this is a two minute job to complete)
I am using the VFD control panel to operate the spindle as it did not seem 100% reliable from the DSP, although I have not spent time to investigate the issue (set function F00 to 4 and F01 to 0 on the VFD to enable this)
Made a vacuum hold down table for cutting some small rohacell parts (see pictures).
90% of my machine time is cutting 3D, as I am not worried about saving time, my 2D routing is not at very agressive depths.
Name:	teamfq 012s.JPG‎
ID:	76908   Click image for larger version
Name:	teamfq 013s.JPG‎
ID:	76909   Click image for larger version
Name:	teamfq 014s.JPG‎
Old 03-09-2009, 06:38 AM
Thanks.
Did you used a gcode to flat the bed or manually via the USB controller?
Old 04-17-2009, 02:23 AM
Router received.
As first impression it's a good costruction.
Here some pictures:
The box:
The tool box:
Front Panel with the delta and, on the right, the cord for the zero tool:
The Hiwin rail guide:
The ball screw:
The plaque:
As wrote the costruction is overall good.
The only thing is that you can't use a transpallet to lift up the router, there are no solid beams at the bottom.
I already emailed this to Taney and he prompt reply me that this will be improved.
I will post others pictures next days.
Ciao
  #11   Ban this user!
Old 04-20-2009, 09:03 AM
The zero tool:
The X axis:
The spindle:
The Z axis:
The electronic:
Back side:
  #12   Ban this user!
Old 04-20-2009, 10:16 AM
cabnet636 is on a distinguished road
i have seen a few of these machines and your photos are great and show what one should expect!! excellent post
jim
James McGrew camaster x3, aspire software
www.mcgrewwoodwork.com
SHM0609 lubrication carveit Excitech routers 10 02-27-2010 06:33 AM
[Emc-users] EMC2 on Ubuntu 8.04 Hardy Heron LTS - official announcement samco LinuxCNC (formerly EMC2) 7 09-02-2009 06:32 AM
Cap and Trade to be Official Policy dynosor Environmental & Alternate Energy 2 03-26-2009 12:29 AM
SHM0609 to buy and users experience yksur Excitech routers 8 02-10-2009 08:56 AM
TEKdrive Servo Drive Official Release Today!! Kookaburra Product Announcements & Manufacturer News 0 05-14-2006 06:32 PM
