Go Back   CNCzone.com-The Largest Machinist Community on the net! > WoodWorking Machines > Commercial CNC Wood Routers > Excitech routers
Excitech routers Discuss excitech routers here.
Old 01-14-2009, 06:08 PM
Field Worker is on a distinguished road
Question Has anyone experienced the Shaking?
When I cut any size circle, my machine vibrates fairly hard, you can feel it in the floor ( concrete) when standing next to it.
Has anyone experienced this?
Old 01-15-2009, 07:14 AM
cabnet636 is on a distinguished road
what software are you writing in!! all vectors work with nodes when they ain't smooth the circle can jerk, next one would get in to settings and speed.
a machine has to look ahead to see where it is going much like a car around a curve, so try slowing down and see what happens.
call me later and we can get on line this weekend (it will be cold on saturday)
do you have internet at or near the machine, if not get it!! i'll show you somthing cool!!
jim
James McGrew camaster x3, aspire software
www.mcgrewwoodwork.com
Old 01-25-2009, 07:52 AM
whole lot of shakin goin on!!
field worker have you had some improvement on the sahking?
jim
Old 01-25-2009, 12:51 PM
Jim,
Yes, I had changed the mode from exact stop to CV, and it was good and smooth. However I'm still broke down but should have it up and running again tomorrow.
Jim,
In another reply from another thread, you mentioned that I should be able to do around 300 imp, Is this in the material or running above? I break bits (.250) if I run at 100 imp. or above.
I was running a 1/2" 2 flute bit in 3/4" mdf at 110 imp with a depth at .375 and stalled the spindle. I have the 3HP and it even stopped the Y axis.
Roger
Old 01-25-2009, 12:59 PM
i cut sheets at 200to 400 ipm and use 3/8" bits at .375 deep per pass, i would not try this in one pass, craig t is telling me he is using 3 flute down spiral with excellent results i am going to try this, got to deal with the horses today will be back later
jim
Unexperienced needs experienced help!!! wilson248 General Metal Working Machines 2 01-13-2009 05:35 PM
centroid m50 problem- need experienced help! Ceramic Man Controller & Computer Solutions 0 05-24-2008 07:34 PM
EXPERIENCED CNC MACHINIST lbi17 Employment Opportunity 2 12-24-2007 12:37 PM
EXPERIENCED CNC LEAD lbi17 Employment Opportunity 0 12-20-2007 10:22 AM
Need experienced advise Metalcraft DIY-CNC Router Table Machines 2 02-13-2007 05:22 PM
